Old 06-02-2011, 08:56 PM
darrell4wd darrell4wd is offline
Vehicle: 2004 Ram 2500
Color: Tan
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
darrell4wd is on a distinguished road
Default wind noise on quad cabs
Hey guys, I couldn't find the thread I read about someone needing help with wind noise so I'll do a new one. I had a problem a couple of years ago and took it back to the dealer. An old guy in the body shop brought a 2x4 out and flexed my door a little (drivers side), using the 2x4 at the bottom. Not much but it did the trick. It started doing it again last summer and I did it myself. Just be careful, don't bend it....
Old 06-02-2011, 10:44 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Thanks for the tip.
Old 06-07-2011, 02:24 PM
dj06482 dj06482 is offline
Vehicle: 2006 Dodge RAM
Trim Level: ST 4X4 1500
dj06482 is on a distinguished road
Are you bending in the front of the door or the rear of the driver's side door?
'06 Ram 1500 ST QC 4X4 HEMI, Magnaflow Duals
Old 06-10-2011, 10:13 PM
chris0001's Avatar
chris0001 chris0001 is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT QuadCab 4x4
Color: SILVER
chris0001 is on a distinguished road
I would also like to know where to place the 2 x 4....My truck has strong wind noise on the highway.
Cheers!
[/SIGPIC]
Old 06-11-2011, 06:33 PM
crazymfer crazymfer is offline
Vehicle: 04 dodge ram hemi sport
crazymfer is on a distinguished road
hey i got a friend in the body shop too he said to adjust your fender so its a little higher than the door.. the air passes over the door ,if the door is higher than the fender thats where your wind noise comes from .. he fixed mine so im not complainging
Old 06-11-2011, 09:13 PM
Rep:2657
the wind or noise is likely coming from the upper part of the door, but to find out
take some blue painters tape & run it over the crease between the door & fender & some more from the top of the fender to the top of the door.
Drive down the road to see if you stopped the noise or breeze.
then you can tear off strips until you feel or hear it again
if its at the bottom of the door, you can adjust the hinges
Wind Noise LadyRam Body & Interior 13 01-29-2012 10:09 PM
2010 Dodge Ram 5.7 quad cab wind noise back right passenger area quibbly 2010 Dodge Ram Forum 13 01-23-2012 05:53 PM
Wind Noise rbu1 2011 Dodge Ram Forum 12 11-26-2010 12:09 AM
2010 ram 1500 crew......wind noise..???? amercnchopz34 2010 Dodge Ram Forum 11 08-16-2010 01:08 PM
Passenger Door Wind Noise? 04ram4X4 Body & Interior 9 03-01-2010 12:47 PM
