Old 06-02-2011, 10:09 PM
samtheman samtheman is offline
Vehicle: 07 ram 1500
Trim Level: big horn
Color: infurno red silver metal flake
samtheman is on a distinguished road
Default leveling
Sorry for not posting in a while still geting used to the site and time is never on my side I do have a question about a 07 leveling kit 2 or 2.5?? and what kind of job am I looking at?? and I would have to assume that an alignment is needed also ??? now enough with the newbe newer dodge questions I was posting in the wrong spot before so Ill just say that the weather did not cooperate last weekend so Ill try agin this weekend with the shine up and posting some pics
Old 06-02-2011, 11:08 PM
Depends on how big a tire you are gonna go with. If you want 33's I'd suggest the 2.5" kit as a minimum.
Yes, you should get an alignment after the kit is installed.
Old 06-02-2011, 11:58 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Well if your truely looking to "level" your truck take a tape measure and measure from the center of your wheel to the lip of the wheel well in the front and back. The difference (back-front) will tell you how high you need to go to be level.
I have a 2" spacer on a 2500 and it actually sits about 3/4" nose high
Old 06-03-2011, 12:15 AM
nYmPhMoBiLe08's Avatar
nYmPhMoBiLe08 nYmPhMoBiLe08 is offline
Vehicle: 2008 Dodge Ram
Color: Metallic Gray
Rep:75
nYmPhMoBiLe08 will become famous soon enough
I just put the Bilstein 5100 struts on the front and got 2 inches of lift which still left me with about 1/2 inch from level. Then i put coilovers in the rear and got an inch of lift so now im about 1 1/2 inches from level. After that i put on new tires that came out to 33.5 inches tall and have no rubbing at all!
~Landon~
Current MODS: | Bilstein 5100's (Front) | Monroe Coil Overs (Rear) | Tow Mirrors | Husky Tool Box | Plasti-Dipped Badges/Gas Cap | 295/70/17" Nitto Trail Grapplers | 17X9" Fuel Boost Wheels | 3" DMH Cutout | RT Stripes \\ | WeatherTech Floor Liners |
Old 06-03-2011, 07:42 PM
Thanks guys I belive it needs 2.5 Im just gona leave the stock tire size p275/60r/20 I think its a good looking size. I just cant stand the nosedive, it looks like its carrying a plow . I could just be used to my old 1st gen 1tons I made them sit level with a couple new leafs these newer trucks are a diferent world to me. Now for the next round of questions since there is no full power screw, timing advance,afc star wheel,big honkin air filter,and pod injectors how do we sqeeze a little more power out of this small mill???
Old 06-03-2011, 11:31 PM
Rep:75
Ive got money you are gunna want to go with a bigger tire once you lift the front 2.5 inches! It will look slightly funny if you dont
~Landon~
Old 06-11-2011, 12:14 PM
marshallsmith44 marshallsmith44 is offline
Vehicle: 2007 dodge ram 1500
Rep:74
marshallsmith44 will become famous soon enough
are you 2wd nymphmobile08?
leveling kit plus suspension lift Jerkbait Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 11 03-15-2011 03:47 PM
HBS leveling kit installed BiggBerger Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 02-07-2011 02:04 PM
2WD Leveling Question bigedschukar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 20 11-18-2010 09:20 PM
Quoted $1373.50 for alignment after Installing Leveling Kit doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-01-2010 11:20 PM
Leveling kit and effect on steering Redlongbed Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 08-11-2010 11:12 AM
