Old 06-03-2011, 11:55 AM
rodanst6 rodanst6 is offline
Vehicle: 2014 Dodge Ram 1500
Trim Level: Limited
Color: Blue
rodanst6 is on a distinguished road
Default Back up camera
I currently have a 430 RBZ radio in my truck and I am looking to add a back up camera, just trying to find out if the head unit supports the camera. The camera I have found has a MOPAR part number of 82211184. Can anybody verify if this will work for me?
Also, I am waiting on an RHR head unit (back ordered forever), if I do get it I am ASSUMING that the camera will work with that as well....any hep is appreciated.
Old 06-04-2011, 10:37 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 06-05-2011, 06:07 AM
farmall farmall is offline
Vehicle: 2003 3500 QC diesel
Color: Patriot blue
farmall is on a distinguished road
I have the RBZ in my truck and it does have the back up camera from the factory. I am not sure of the part # info.
Old 06-05-2011, 09:42 AM
brokenwrench66's Avatar
brokenwrench66 brokenwrench66 is offline
Vehicle: 2009 1500 SLT 4X4
Color: Stone White
Rep:81
brokenwrench66 will become famous soon enough
The RBZ replaced the REN so the back up camera you mentioned will work with it. I has to be activated by the dealer though so you may want to see what they'll charge you for that and compare that to what they'd charge you for a complete install.
Here's the install instructions if you want to put it in yourself.
http://moparestore.trademotion.com/m...K6869459AB.pdf
Dual Exhaust, K&N drop in, TFP chrome mirror covers, TFP stainless steel door handle covers, molded splash guards, Leer cap
Old 06-06-2011, 09:41 PM
Trim Level: Limited
Color: Blue
Thanks to all, I got it activated today and it works, no problems.
Old 06-06-2011, 10:05 PM
my11ram's Avatar
my11ram my11ram is offline
Vehicle: 2011 dodge ram sport
Trim Level: sport 4X4 Reg cab
my11ram is on a distinguished road
Thinking of adding one too. Did you do the install yourself? If so how complicated of a job is it? My salesman told me it would be four hours at least of shop time and I can't believe it would take them that long, maybe there's more to it than I think.
Old 06-07-2011, 12:52 AM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
The hardest part when I ran my cable for my backup camera was routing it. It follows a meandering path through the tailgate, above the spare tire, along the frame, up the fender, through the firewall and behind the radio. It took me a while to get it all secured in place.
That said, I'm not a professional mechanic who works on these things full time. I took my time and was very cautious about where things went. I would say it took me about 4-5 hours to mount the camera (I used non-factory CMOS2 camera) and run the cable all told. It's not a hard job but it is tedious since the cable needs securing in a few very tight places.
Old 06-07-2011, 09:32 AM
Trim Level: Limited
Color: Blue
I installed the camera at the same time I installed the power locking rear tailgate handle (if you are going to do both, do them at the same time) and it took me about 4 hours to be honest. Getting the new tailgate handle (it has the camera built in) installed was easy, and as Rough 01 said the longest part is running the wiring up to the engine compartment, its not hard just time consuming. Splicing the wiring in was not bad, I just took my time and read the directions and it worked out okay.
I did it myself for the same reason, they told me it was 3-4 hours of labor at $100 an hour.
I wish I had installed the remote start myself when I had that put in could have saved some money there too!
Front Camera Install Questions RootBeer Custom Dodge Ram Interior Modifications - Custom Audio / Video 16 02-03-2015 08:16 PM
New Muffler = Loss of Power??? BigOrange Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 15 07-05-2014 01:27 AM
Back Up Camera Foggy Rugged Brown 2010 Dodge Ram Forum 4 12-07-2010 06:09 PM
Added Magnaflow Cat back and lost some low end! Thetolleyman Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 10 11-23-2010 04:34 PM
Rear Camera Confusion... CustomShirts 2010 Dodge Ram Forum 21 05-12-2010 01:13 PM
