Bad Rims? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-03-2011, 04:47 PM
FriscoRam's Avatar
FriscoRam FriscoRam is offline
Vehicle: 2010 Laramie
FriscoRam is on a distinguished road
Exclamation Bad Rims?
I just purchased a pre-owned '10 Ram Laramie that had some 22" Gitano rims on it. It had a bit of wiggle in it, so I took it Discount Tire to get those big wheels balanced. They informed me that Ramtrucks have "flared" lugs that prevent these aftermarket rims (with a completely flat mounting surface) to fit snugly or firmly against the hub, which is what was causing the vibration. Thus, creating a safety issue - they wouldn't even balance the rims.
So, should I try to fight the fight with the dealer and see if they will replace the faulty rims with OEM Ram wheels, or is there an off-the-shelf solution to this problem? Has anyone else heard of this? I've scoured the net with Google and can't really find anything relating to this specific issue.
Old 06-03-2011, 05:04 PM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
The factory rims have a 60* connical seat in the lug holes and the lugs have a 60* connical base. If your current rims are flat based then simply get new lug nuts to match the wheels. If the tire store couldn't even figure that out I would seriously consider taking my buisness to a store with more educated technicians.
Just Got it, Give me time!
Old 06-03-2011, 05:12 PM
FriscoRam's Avatar
Thanks for the reply.
But, its not the lug nuts that are the problem. its the back of the rim where it meets the hub. the rims are completely flat across the back but the lug has a small flare right at the base which prevents the wheel from fitting firmly against the hub.
Old 06-03-2011, 05:16 PM
Color: Granite
Rep:286
Odd? My hubs are perfectly flat. Are you sure they are not mistaking the factory disc retaining clips for something else? If they are the little round retaining clips you can take them off. They are just there for assembly purposes at the factory.
Old 06-03-2011, 05:26 PM
FriscoRam's Avatar
no. the the discount tire guys removed the brake clips and showed me the flare on the lugs, then demonstrated to me how the wheel kinda wobbles when they put in on the hub instead of fitting flat against it.
Old 06-03-2011, 05:32 PM
Color: Granite
Rep:286
Have you thought about taking the wheels down to a local machine shop and having them recess the back of the wheel at the stud hole a few thousandths? It wouldnt be hard, heck you could do it in your garage if you needed too. Just get a 3/4" bit and take the smallest of nibbles off the back of the lug hole, just as if you were counter sinking a screw.
Old 06-03-2011, 05:54 PM
FriscoRam's Avatar
Yes. I've thought about it, but that could compromise the structural integrity of the rims. Otherwise, I suppose I could try to find some aftermarket lugs to fit these. Though my preference would be to trade them for the factory 20" rims. Anyone interested? :-)
Old 06-03-2011, 07:10 PM
Color: Granite
Rep:286
I don't understand, if the raised area is on the hub, at the base of the stud as you describe, new lug nuts won't help anything. Your still stuck with the same issue.
Old 06-10-2011, 12:39 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I think I speak for all of us in that a picture would be worth a 1000 words here. It doesn't appear that anyone is tracking exactly what you are describing.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
SS/T or Indy Rims + tires? 98sst Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 1 03-12-2011 07:15 PM
*For sale - 1998 Dodge Ram SS/T Limited Edition rims and tires in good condition* cannotdodgethedart Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 13 11-11-2010 08:38 PM
so pissed off regarding tires and rims mineralram Dodge Ram Wheels And Tires 7 08-27-2010 11:20 PM
Rims for winter RAM2009 Dodge Ram Wheels And Tires 0 03-08-2010 09:35 PM
17" rims VS. 20" Rims infantryman2oo2 LD RAM - General Discussion 13 11-01-2009 03:54 PM
