Old 06-03-2011, 07:10 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Default EFan install
Finally did it. Installed a Flex-a-lite electric fan(part #294), so far it's working great. 6000cfm. Consulted with the Flex-a-lite people, and the guys at Summit regarding the alternator. Fan draws 28-36amps, wanted to make sure the alternator would handle it. Both said the fan starts up at 60% power, then ramps up so as not to be to hard on the charging system. Had to pretty much cut the shroud in half. The only reason it is needed is for mounting the overflow bottle and windshield wiper fluid reservoir. I can tell a definite difference when accelerating, truck feels alot lighter. Doesn't take as much to get it moving. The "Ass Dyno" is telling me not to start checking mileage for a week or so! Water pump started leaking as soon as I took the belt off, so it got a new one, as well as a new thermostat, new hoses, and a new serpentine belt. Truck has a little over 90K miles, so I figured it was time for some preventative maintenance.
Old 06-03-2011, 09:54 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Very clean install! Nicely done. Hopefully it'll help free up some mpg's! I can't see why it wouldn't.
Old 06-04-2011, 12:12 AM
Color: Garnet red
Rep:202
Still need to clean up the fan shroud, the top hose is a little close for my comfort. Also, I had to shim the driver's side because the fan was rubbing on it. Hoping that cutting some more off the shroud will fix this. The disc in the cut-off tool exploded before I was done. Haven''t used them much, but I guess this is common. Once I am certain things are working out, I'll neaten it up a little more. Thanks.
Old 06-05-2011, 06:00 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Hey do you have a link to the fans you bought?
Old 06-06-2011, 01:57 AM
Color: Garnet red
Rep:202
Here's the Flex-a-lite link, and the Amazon link. Amazon had the best price I could find. I've read that some are modifying efans off the Ford Taurus. I was more comfortable getting something with a warranty and support.
http://www.flex-a-lite.com/auto/
http://www.amazon.com/Flex-a-lite-29...7336075&sr=8-1
Old 06-06-2011, 06:27 AM
SPC.Brinkmeyer's Avatar
SPC.Brinkmeyer SPC.Brinkmeyer is offline
Vehicle: 1997 Ram 1500
Trim Level: SLT/Laraime
Color: Red/Silver
Rep:14
SPC.Brinkmeyer is on a distinguished road
looks like a nice setup man... now to try and clean up them wires a lil n make em look a lil neater... i have to instal a switch or a tstat on mine somehow its wired to a constant hot the guy that put it on before i got the truck had it wired to be constant hot all the time when the key is on. this past winter a 30min trip you could still touch the block the gauge wouldnt even pull up off of cold
ANOTHER USLESS POST BROUGHT TO YOU BY NOONE
Old 06-06-2011, 07:39 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Nice job on the install.
Old 06-06-2011, 12:33 PM
soco native's Avatar
soco native soco native is offline
Vehicle: 02 ram 1500 5.9
Trim Level: slt sport package
Color: BLACK
soco native is on a distinguished road
Nice job man, good pics to follow when i do mine
TWIN TURBO IN THE WORKS!!!
Built for boost short block by PIE, forged internals, PIE by JE blower pistons, Edlebrock MAX port heads, PIE turbo cam, Comp Turbos, JGS waste gate and BOV, SCT tuned by PIE and DIY 304 SS sch30 pipe turbo manifolds.
Old 06-06-2011, 03:30 PM
Color: Garnet red
Rep:202
I left the extra wire so I could clean it up after I knew everything worked. So far so good. You can get just the variable temp control and wire it in. You may need to wire to the AC a well so that the fan comes on when the AC is on. I still need to trim the shroud some, the cutoff disc kinda exploded on me when I was about 80% done. Shout out to Kenny, a coworker who helped me get the whole thing wired up.
Old 06-06-2011, 09:59 PM
Color: Red/Silver
Rep:14
do you know where i could get a temp control to wire in... also do you have a wire schematic that i could use for the setup that would be greatly appreciated
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 01:06 PM
HID Install 09/10 RAMS doz Custom Dodge Ram Interior and Exterior Lighting 14 03-20-2011 02:28 AM
Audio install w pics.... airbag light :( pankster Custom Dodge Ram Interior Modifications - Custom Audio / Video 8 01-25-2011 01:46 AM
Amp Install Complete - with Pics colingibb Custom Dodge Ram Interior Modifications - Custom Audio / Video 20 01-25-2011 01:35 AM
Computer won't install device driver? wickedpissahtruck Diablo Predator Questions & Info! 5 11-08-2010 06:28 PM
