Old 06-06-2011, 02:49 PM
moose3 moose3 is offline
Vehicle: 2011 Ram
Trim Level: Sport Crew w/Rambox
Color: Deep Cherry Red
Rep:36
moose3 is on a distinguished road
Originally Posted by Razorbass View Post
If you can figure out how to make the Avalanche panels work on a bed with the Ramboxes, that would be awesome! I would consider selling my BakFlip if I could get that setup at a reasonable price. Please keep us posted!
Crazy part is I think it will be close. Avalanche bed is about 4 inches shorter, and the same width.
Old 06-06-2011, 04:44 PM
ELFATKAT's Avatar
ELFATKAT ELFATKAT is offline
Vehicle: 2011 Dodge Ram 4x4
Rep:30
ELFATKAT is on a distinguished road
Cool Thanks for the write up
I have been seriously considering this cover. I finally realized the difference between the G2 and F1 or whatever they call it. I would definitely go with the cheaper one. I probably will not sit or stand on it and I will just not touch it so much when it is hot out. Obviously if you need to open it and it is hot, then you will need to use some gloves or something. The G2 will still probably be a little hot. I am from Texas so maybe when I move back I will upgrade.
I still have not decided, but thanks for all this information. It will definitely help.
Carlos "ELFATKAT" Medina
www.carlostmedina.com
Old 06-06-2011, 05:26 PM
Vehicle: 2011 Ram
Rep:36
The F1 also is dent resistant, the G2 is not. IE HAIL.
Old 06-06-2011, 10:33 PM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
If it hails enough to damage the bed cover wouldn't there be more damage to the rest of the truck as well? I know my insurance will replace the cover as well as fix my truck. So I'm out the same $500 deductible no matter what.
Old 06-29-2011, 09:07 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
Originally Posted by moose3 View Post
I will take my thermo with me to work tomorrow. 95 degrees and full sun tomorrow. I am going to measure the panel system of the Avalanche to just make SURE it won't fit, because if there is enough real estate in the bed, I can make it work.
Moose - Just a follow up note but did you ever try to figure out a way for the Avalanche panels to work?
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 06-29-2011, 09:57 PM
Vehicle: 2011 Ram
Rep:36
I didn't after I used the Bakflip for a few weeks, I decided that I could live with it. I am $800 into the Bakflip it is installed and a set of Avalanche panels probably would set me back almost $1000. As if remember right they were like $600 each new. There are somethings about the Bakflip that I actually prefer. If you want to access the front of the bed, it is much quicker and easier to flip the Bakflip up than it would be remove the 3 panels of the Avalanche. The quality of product is not even in the same class as the OEM panels on an Avalanche, that is not even arguable, but the ease of use may have be hooked, now that I have it.
Like I said in the post on the other thread, once you come to terms with the build quality of the Bakflip it really is something that works well. Just man it could use a bump in manufacturing quality.
Old 06-30-2011, 05:14 PM
Razorbass's Avatar
Woo Pig Sooie!
Rep:95
^^^^Totally agree.
Old 06-20-2013, 09:07 PM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
Well everyone here is my review of the Bakflip F1 for Rambox.
It took about a week for my Bakflip to arrive. It was packed very well, everything was nice and tidy in the package. I watched a video of the install on Youtube and the instructions feature color photos, so the installation process is not to hard to get figured out. The kit installs with just basic hand tools.
I bought this cover because I needed something that was easy to remove/fold up on a fairly regular basis, and I haul motorcycles so I couldn’t have the wasted 6 inches at the top side of the bed, that is where front wheel of a bike hits. I also wanted a cover that I could sit something on. Now that the cover is installed it looks great, the rubber flaps that go all the way around the edge lay and down and seal very nicely, they have a decent amount of pressure on them to keep them sealed up. The cover folds up easily and can be put in the locked upright position with ease. The cover doesn’t lock up right completely rigid, so I think on big bumps it will bang around. It is also marketed as been non-heat gathering, but today it was 90 degrees and sunny and it got hot enough that would barely want to touch it for more than a moment. This may be cooler than the all aluminum ones, but not without heat. One more thing is that you have to open the cover before you can close the tailgate.
I did run into some issues with the install. The drain cups for the rear of the mounting rails was not cut to accommodate a clip that holds the bed cap corner down. So I had to cut that to make it fit (see photo). The right angle aluminum that works as the catch for the latches is slotted to allow you get it to the proper height, but the captured nut embeds itself in the back of the brackets, which makes them rather difficult to adjust. Once I had them all adjusted and installed I installed the panel system. But when I flip the panels down to the latches are wider than the catches, so they will not close. The latches were 1/8” too wide. I emailed Bak and then called them. The customer service rep told me that they would have a senior tech call me back. Well I never heard from them.
I could have waited days for them to call, we shall see if they ever call back. I could have demanded a return, but I want the cover and I had already waited a week to get it. So I decided to remedy the situation myself. I removed the catch brackets and marked them off and took them to my industrial belt sander. I removed a 1/8 from each bracket, so I would have clearance to latch the cover. I then put a nice radius on the corners something that Bak didn’t do. I repainted them and reinstalled again dealing with the difficult to adjust part. The cover still would not latch now because the latches on the cover are plastic and the edge of the catches would dig in. I then had to take a sanding flap wheel and radius the edge to get a nice smooth edge. The cover now fits and latches just like it does in the promo video they so proudly show us.
Now for the disappointment part in the system in general, the bracketry that comes with it, while fully functional is kind of crude. The catches are a piece of cut down angle aluminum, with slots in them. The corners just knocked off, rather than taking the extra 5 seconds to radius the corners on the same sander they are using to knock the corners down. (see photo) The retainer for the prop rod has to be the most disappointing piece, it is a ˝ inch chunk of angle aluminum that is hand drilled and sanded, then has a plastic wire retainer riveted to it. (see photo) This is the kind of the thing you go hey that will work, when you are engineering in your garage, not what you expect on a cover that is $900-$1000! Yes it does the job. For a company that is touting that they build OEM parts for one of the BIG 3, I am not sure how this level of quality can pass.
I like the cover, it works, it was just a long journey to get it on and right. I don’t have any intentions of replacing it, and yes I may even consider it for another truck. I was suggesting a Rollbak for my dads truck (different set of needs), but I may now look into a similar design by a different manufacture.
Take this information and make your own purchasing decision.
Hi Moose3 thanks for the review.
I have a question for you that I wondered if you could help me out with?
I too have Ramboxes and have the F1 halfway installed, but I came across a situation on the mounting rod assembly similar to what you were talking about.
Could I trouble you to take a picture of the two pieces that make up the positioning of the mounting rod and post it?
I would be talking about the pieces in steps 7 and 8 of the installation.
I'm pretty sure that Bak sent me the wrong parts (though I'm sure I could make it work), but I'd be curious as to how your setup looks.
Here is the piece that they sent me that I think is wrong, but workable.
Thanks.
Old 06-23-2013, 12:52 AM
Chunkem's Avatar
Chunkem Chunkem is online now
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Great write up......
Old 06-23-2013, 02:08 AM
RedSmart's Avatar
Rep:883
Never mind answering my question, I figured it out.
Thanks anyway.
BakFlip F1 Review for those Curious Folk LeKy411 2011 Dodge Ram Forum 30 06-07-2012 01:29 AM
BakFlip tonneau covers for RamBox equipped trucks Dan 2009 Dodge Ram Forum 8 02-04-2010 12:01 AM
