Old 06-05-2011, 07:36 PM
dodgeman9859L dodgeman9859L is offline
Vehicle: 1998 Ram 2500
Trim Level: SLT 4x4 QC
Color: Dark Red
dodgeman9859L is on a distinguished road
Default still having an idle and power issue
hello gentleman. im stil having an idlin issue when my truck isnt upto operating temperature. was told it might be the intake manifold gasket leaking. i just had the plenum gasket done about 4 months ago. is this a possibility asi thought it was all one thing so is there two levels to it or whats the deal. any help is greatly appreciated. thanks.
Old 06-06-2011, 12:52 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
You take the intake manifold off to get to the plenum gasket. When the intake manifold goes back on, there is another gasket that seals it. If the problem started after the plenum gasket repair, it's possible the intake manifold didn't get torqued down right. Squirt some carb cleaner around the intake manifold and see the idle changes. If it does, then there is a leak. Not a fool proof method, but cheap enough to try. Good luck.
Intermittent power loss, 2002 5.2 pred Dodge Ram Vans 7 01-23-2012 04:46 PM
DC to AC power converter - Anybody got big AC power ? Power Tool? cyberpine 2010 Dodge Ram Forum 5 03-06-2011 03:05 PM
no power to condenser motor / it's all *%$&'d up 05atlanticblue Heating & Cooling 11 08-08-2010 05:58 PM
Spark Plugs, Horrible Gas Mileage, Somewhat Rough Idle! JNoles05Ram 3.7L PowerTech V6 Specific Topics 3 06-17-2010 05:21 PM
Uneven idle yellow ram 5.9L V8 Specific Topics 2 05-29-2010 05:46 PM
