tonneaucovered.com
Old 06-06-2011, 08:52 AM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Exclamation remove brake fluid rez?
Has anyone removed the brake fluid rez to totally empty/clean it out? I used a turkey baster to suck out the fluid, but there is still some 'coffee' colored old brake fluid in the rear chamber -- about 3/4" that isn't draining to the front chamber where it can be sucked out. Just wondering what can of worms I may be opening up?
Old 06-06-2011, 10:21 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Have you thought of taking some high quality paper towels to mop put the remainder of the fluid? The bounty towels are almost lint free and would work well.
Old 06-06-2011, 10:33 PM
Trim Level: LT
Color: almond
Rep:19
Unhappy towels
Yes, I did do that, BUT if your rez is like mine, the lid is over the front chamber, then there is a dividing wall, then the rear chamber. After the front is empty, the rear still has about 3/4" of old fluid in it you can't get out with a turkey baster or paper towels. Bad design. I like the old metal ones with the snap ring holding the lid on. MUCH easier to clean out/remove 100% of old fluid + any dirt.
Dodge Ram Van Conversion Window Replacement... ramvan2500 Dodge Ram Vans 4 05-24-2011 11:32 PM
My first post... About my Ram and Work Done ramvan2500 Newbie Checkin! 14 04-24-2011 07:23 PM
Easiest way to Remove 3rd brake light? RammD 2010 Dodge Ram Forum 10 04-23-2011 02:47 AM
brake fluid leaking bad! npoe25 5.9L V8 Specific Topics 6 06-19-2010 03:18 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
