Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Electrical
Old 06-07-2011, 01:41 AM
deervalley deervalley is offline
Vehicle: 2008 Dodge Ram
Color: Grey
deervalley is on a distinguished road
Default Electronic Throttle Control problems “limp mode”
I disconnected my wiring harness on my 2008 Ram and am stuck in limp mode. The truck really will not do much more than crawl at an idle and the ETC light comes on. I know that I started it up without having the harness plugged into the gas pedal POT switch or what ever it is. Do the Rams with the drive by wire systems require some sort of special relearn procedure in order to get out of limp mode if they are started with the wiring harness unplugged?
I have searched all over this site and not found an answer. Any help would be appreciated.
Thanks, Larry
Old 06-08-2011, 03:47 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 06-08-2011, 09:35 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Wow that's a brain teaser. I'm guessing not many people have encountered this, you may call your local dodge dealer, or better yet, go in and actually talk to a service guy, they will most likely help you out face to face. Why were you disconnecting harnesses anyway?
Sean
Old 06-09-2011, 04:06 PM
Color: Grey
Thanks for the bump Redram
snrusnak,
Well its a long story and a stupid one at that. I made a mistake and it has done nothing but snowball. It is somewhat documented here at this link:
http://www.ramforumz.com/showthread.php?t=68949
as far as talking to the service guy, that is not possible at the closest dodge dealership to my house. they have been unhelpful at best!
Old 06-09-2011, 04:57 PM
snrusnak's Avatar
Rep:1385
It sounds to me like it needs a relearn procedure of some sort(check the harness one more time though!). The electric motor needs to identify the position of the pedal. This is all my opinion I've never dealt with this on this truck before.... I would really try calling another dealer then if that one won't help you, and pry and try to find out from the actual guys who work on the trucks, not the guy at the counter, if there is some procedure for this. Good luck, sounds like this is your only remaining issue! If you go back to everything stock, does it run fine?
Sean
Old 06-09-2011, 05:59 PM
Color: Grey
Well, I talked to a service rep at the dodge dealership and he said they will take a look at it for a hundred dollars. I still cannot get him to let me talk to the techs. I will have to have it towed out there and I have no idea what they will say once they look at it, but I am hoping that just relearning the ETC will do the job. This service rep will not even let me talk to the tech to explain the mess I made. I have to write a letter to the rep and put it on the dash.
Old 06-09-2011, 08:18 PM
Rep:2657
do you have any dash lights on?
check engine or lightning bolt, or any other?
can you drive it to a local autozone or anything to get the codes read?
write the codes down, if there are any, then they can clear the codes & it may straighten itself out
Old 06-10-2011, 06:43 PM
First things first....let's let the PCM relearn/reboot by disconnecting the negative side of the battery for 30 minutes.
Make sure all your harnesses are re-connected properly.
Then re-attach the battery cable and start it up.
Old 06-10-2011, 07:07 PM
07yt1500thunderroad's Avatar
07yt1500thunderroad 07yt1500thunderroad is offline
Vehicle: 2012 passat tdi se w sunroof
Rep:70
07yt1500thunderroad will become famous soon enough
I'm with him usually anytime you mess with the electrical system you have to do this to make the computer reboot.
Old 06-11-2011, 08:53 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I got stuck in limp mode once. It happens to all of us at some time or another. Mine just went away on it's own. If yours doesn't fix itself you could always try this....
www.viagra.com
I'm sorry, I couldn't resist!!!! In all seriousness, have you tried the battery disconnect? Did it work? If not, anything new?
Trasmission Help!!! bigjeff64 5.9L V8 Specific Topics 16 03-16-2015 11:49 AM
ETC Throttle Body Cleaning Procedure RamTech Dodge Ram Knowledge Base 8 01-30-2014 05:53 PM
Electronic Throttle Control HoltFF1074 Electrical 2 01-13-2010 11:17 PM
Electronic Throttle control light? wester399 Dodge Ram General Discussion 4 01-07-2010 11:44 AM
03 electronic throttle control???? carscars11 5.7L V8 Specific Topics 1 09-05-2009 02:27 PM
