Wheel Bearing Assembly - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 06-07-2011, 10:09 AM
RamLamm's Avatar
RamLamm RamLamm is offline
Vehicle: 2001 Dodge Ram 5.9L V8
RamLamm is on a distinguished road
Default Wheel Bearing Assembly
I was trying to replace my passenger front wheel bearing assembly this weekend. After two solid days of trying to get the spindle nut off, it didn't budge. I successfully broke all the tools I used. I used a 6 foot cheater bar 1/2" breaker bar, that just sheered the end off. No worries, I'll get em all replaced by sears. In addition to breaking all the tools, I put about 1000 ft/lbs of torque on the nut, some how the U-joint end casting popped off.
Just wanted to point out that if you're trying to replace the assembly, you're going to need some heavy duty equipment to get the spindle nut off. Seems that the nut is rust welded on there.
Will be heading to the shop this weekend to have them do it.
"We live by the sea, We die by the sea."
Old 06-07-2011, 11:13 AM
SPC.Brinkmeyer's Avatar
SPC.Brinkmeyer SPC.Brinkmeyer is offline
Vehicle: 1997 Ram 1500
Trim Level: SLT/Laraime
Color: Red/Silver
Rep:14
SPC.Brinkmeyer is on a distinguished road
i just did one on my dakota...
on that we were supposed to pull out our cotter pin and the nut keeper then bolt the wheel back on sit the truck completly on the ground and then break the nut loose... mine was quite rusty but i sprayed it with some industrial strength penatrant and waited an hour after i sat it down and then went out and it came off... with a harbor freight 1/2"dr. breaker bar that was 14" long with a 2' cheater pipe that i realy probly didnt need too aweful much... the dakota torqued to 185ft/lbs i belive it was...
ANOTHER USLESS POST BROUGHT TO YOU BY NOONE
Old 06-07-2011, 04:07 PM
kawi348 kawi348 is offline
Trim Level: Lariat
Color: Maroon
kawi348 is on a distinguished road
I just got mine back today from a shop. I had the wheel bearings replaced, all tie rods, and U Joints...it all costed $913 ...but I know the owner personally so I got an awesome deal.
Old 06-07-2011, 04:48 PM
RamLamm's Avatar
Wow you did get a good deal on that. I'm going to get both wheel bearing and the one u-joint done. I recently had the other U-joint done.
Old 06-07-2011, 10:25 PM
toddub toddub is offline
Vehicle: 1995 Dodge Ram 4x4
Trim Level: SLT Larrmie
Color: Green
Rep:22
toddub is on a distinguished road
I just did mine on Friday. I had to use a 1-11/16 3/4 inch drive socket with a Snap On 3/4 Breaker bar. We duct taped the winch cable from my buddy's truck and stood back about 20 yards. There was a terrible creeking sound, but it broke loose!
While we were able to successfully break it loose, it still took a lot of effort to get the nut off. Total cost was a case of Miller Lite and about $180 for aftermarket bearing assemblies. I guess that's why I got the truck so cheap. Good Times!
Old 06-10-2011, 12:10 PM
RamLamm's Avatar
Nice work on getting the nut off. I finally gave in and dropped it off to the shop. Having them do both wheel bearing, the U-joint that I busted, and both seals in the diff. I paid for both wheel bearings. All said and done, just under $1000.
Old 06-14-2011, 10:08 PM
Zac2109's Avatar
Zac2109 Zac2109 is offline
Vehicle: 2011 RAM 2500
Rep:56
Zac2109 will become famous soon enough
I just did the passenger side wheel hub assembly on my 2500 on sunday and it was a pretty big pain in the ass, just out of curiosity what size socket did it take on the axle nut? the reason I ask is Im getting ready to change out the one on my buddies 1500 and was needing to know what size it is.
2011 RAM 2500 6.7L Cummins, 1968 Ford Mustang Coupe 289 V8
Old 06-14-2011, 11:11 PM
Even once you get the axle nut off , the real fight is getting the hub/bearing assembly out of the spindle . I've spent days on a 3/4 ton getting it apart .
Old 06-15-2011, 11:10 AM
Zac2109's Avatar
Rep:56
oh yea Tom I know, I just did that on sunday, and my 3/4 ton is 13 years old so things were good and stuck on there. spent around 4 hours trying to convince it to come off with the help of a "BFH" and if your not sure what BFH is...its a Big F@#$in Hammer LOL
Old 06-15-2011, 11:45 AM
badazram's Avatar
badazram badazram is offline
Vehicle: 1995 Ram 2500
Trim Level: Laramie Slt
Color: Green
Rep:72
badazram will become famous soon enough
Thumbs up
i had to replace my front universal on the passenger side and a 4 pound hammer with a chisel and punch the hub bearing decided to come apart =p i was really surprised at how easy it came apart
Common sense is genius dressed in its working clothes
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Replaced Bent wheel bearing... ramvan2500 LD RAM - General Discussion 2 05-06-2011 03:05 PM
Wheel bearing failure? babylacyjane Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 03-23-2011 05:34 PM
Question on front wheel bearing assembly. Beauacadian Suspension 1 03-04-2011 11:15 PM
Newbie with wheel bearing issues danielfochtman Newbie Checkin! 5 11-11-2009 09:37 AM
