Old 06-07-2011, 04:12 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
Default 35'' MT on stock Outdoorsman rims
Hi guy's, new here and i should have my truck tomorow or thursday.
It's a Ram 1500 4x4 Outdoorsman Crewcab and yes it got the Hemi I want to level it in the near futur, but i would prefer to keep the stock wheel for now. Stock wheel are 17x7 i think and i would like to put 35'' MT (315/70R17) on them.
Will it fit on stock wheel and a leveling kit or will i need wider wheels?
Almost forgot, if someone have picture with 35'' on stock 17'' i wouldn't mind to see them.
Thank
Pat
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 06-07-2011, 04:44 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
+1 on the pics.....post 'em up!!
Are you asking if you can do 35s stock or 35s and a level. You're wheels should be fine tho, may balloon a little. It'll definately work with a leveling kit. Not sure about stock height, someone that knows for sure.....
[CENTER][SIGPIC][/SIGPIC]
Old 06-07-2011, 04:46 PM
Are you asking if you can do 35s and stock or 35s and a level. It'll definately work with a leveling kit. Not sure about stock height, someone that knows for sure.....
With a leveling kit, but on stock wheel. They're only 7'' width and i think to fit 315 you need atleast 8'' width wheel.
Old 06-07-2011, 04:55 PM
candy08's Avatar
Rep:213
Ou can run 35s with a level no problem!
Im running 35x12.50x17 Federal Couragia Mt on my stock JK 17x7.5 wheels....
Old 06-07-2011, 05:01 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I think that the rule is you want the tread width within 4 inches of the wheel width. You can fudge this a little, but the more you get past this, the more likely you are to have a bead that doesn't seat right and breaks loose under stress, like in a turn.
On the JK, the curb weight is a lot less than on our trucks, so it isn't as likely to be an issue, but still I wouldn't push it by taking turns too fast.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-07-2011, 05:34 PM
candy08's Avatar
Rep:213
Just did some digging and you need a wider wheel to go 315/70/17.
Good info Wildcat, rep to ya!!
Old 06-07-2011, 08:42 PM
That's what i was thinking.
Why did Dodge put 7'' width rim on the Outdoorsman If they were 8'' it would of been ok.
I guess i'll have to buy my black KMC XD Addict sooner
Old 06-08-2011, 11:02 AM
Wildcat's Avatar
Rep:166
Just about everything boneheaded on our truck is a direct result of the government and the demand for higher EPA MPG ratings. Narrow rims mean narrow tires, which are lighter and have less rolling resistance to get better mileage.
Old 06-08-2011, 11:56 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
There only a 17 inch rim? Thought 20's were pretty much standard now...
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 06-08-2011, 02:31 PM
It's just stupid, because 7'' is right at the limit for 275.
Rim width range for a 275/70R17 (stock on Outdoorsman) is 7'' to 8.5''
They should of put 8'' atleash. Stock 20'' are 9''
Outdoorsman come with 17'' ''Off road'' tires.
New rims stock tire & tpms Eiphaz10 2011 Dodge Ram Forum 2 03-06-2011 06:36 PM
BIGGEST Tires...Stock Rims...Lift Kit????? ThunderRoad Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 02-16-2011 04:55 PM
FS: Stock 2010 Laramie 20" rims and rubber xopt1js Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 5 10-16-2010 07:54 PM
finding stock rims? 20ramquad04 Dodge Ram Wheels And Tires 14 07-29-2010 10:18 PM
Tire thread for stock 20" rims hokunahooikaika Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 08-11-2009 07:44 PM
