Whats next? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 06-08-2011, 12:26 AM
KingSmokey KingSmokey is offline
Vehicle: 2010 dodge ram sport
KingSmokey is on a distinguished road
Default Whats next?
I have a 2010 ram 1500 sport with a dynomax cat back system, k&n cold air intake kit, and superchips cortex programmer I would like some more suggestions on what to do next. NEED MORE POWER PLEASE HELP
Old 06-08-2011, 12:41 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
welcome to the Z!
tell us a little more about your truck..4wd vs 2wd, what gears do you have, do you have a budget, what are your goals, are you worried about warranty.
if you have the 3.21s or 3.55s I would def upgrade the gears to a 4.10 or 4.56. if you have the 3.92s I would prob leave them alone but 4.56s would still be an option.
you could do a cam, heads, magnuson supercharger
a cheap mod in the mean time is to swap out your 203 degree t-stat for a 180 degree.
Old 06-08-2011, 12:56 AM
Thank you very much for the quick reply. It is 4wd but i am not sure what the gears are. I do have a bit of a budget. The truck is all black with 2" wheel spacers and color matching hard toneau cover with the 20's. The truck is street only no off road. I am not sure how to find the info on the gears.
Old 06-08-2011, 01:04 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
.. I concur ... also consider efan, tq vertor, Y pipe, ported tb...
Old 06-08-2011, 08:21 AM
CHVYKLR's Avatar
Rep:252
there will be a sticker on your rear axle tube tellng you what gears you have. see link: http://i647.photobucket.com/albums/u...Axlelabels.jpg
you can also find it on your window sticker too if you boght new.
gears would be kinda expensive b/c you are 4wd but would be the most bang for your buck depending on what ratio you currently have.
fred also has some good more budget friendly ideas: throttle body, remove your belt driven fan (you have to install the 180 t-stat with this and use your programmer to change your efan on/off settings)
Old 07-18-2011, 04:25 PM
XC450's Avatar
XC450 XC450 is offline
Vehicle: 2006 QC Hemi Ram
Trim Level: Lone Star
Rep:37
XC450 is on a distinguished road
So are you saying that you can remove your belt driven fan and completely rely on your elictric fan? OR are you saying to add an additional electric fan and remove the belt driven fan?
Also, do you have to change your settings for the fan if you put a 180 degree t-stat?
Thanks,
XC450
2006 Ram Hemi QC - HemiFever - DiabloSport Predator - Jet 180 T stat - K&N cold air - Pacesetter LTs & Y-Pipe - Flowmaster Hushpower - 5" side exit - 6" lift - 35x12.5x20 Toyo MT - 20x10-24 Fuel Hostage - Summit Racing Drilled & Slotted Rotors - Ceramic Pads
Old 07-19-2011, 05:02 PM
CHVYKLR's Avatar
Rep:252
Thanks,
XC450
On the 4th gens yes. I am only running the stock efan with a 180 t-stat. I think the 3rd gen folks have been adding an additional efan (Lincoln MKVIII, Ford Taurus, Black Magic, etc).
I changed my fan settings to 186 (low) and 196 (high) with my DSP. The efan runs constantly anytime the AC is running.
