Old 06-08-2011, 02:57 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Cam Swap
I want to replace my cam with the Comp 260. My motor has like 85000 right now, what else should I replace internally along with my cam while I have it in the shop? Heads would be nice but expensive. Would it be smart to just replace the cam or would I risk engine damage? Thanks!
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 06-08-2011, 04:25 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
If you got it apart for the cam I'd think there would be other worn parts you should replace, but not being an engine expert I'll wait for one to chime in......
Old 06-08-2011, 04:52 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
since you'll have all the accesories off it would be a good time to do the timing chain. as far as the heads (springs, push-rods, etc) I would do a visual inspection and go with the advice of the installer.
does the comp 260 require better springs?
Old 06-08-2011, 08:15 PM
chefred112's Avatar
Rep:656
with that mileage..i would do head gaskets and exhaust gaskets as well (proactive maintenance)...also, with the 260, get 6.1 exhaust valve springs (16x) and 6.1 pushrods. headbolts, crank bolts and cam bolt...
Old 06-08-2011, 08:17 PM
chefred112's Avatar
Rep:656
at 201k miles i still run the same original timing set
Old 06-08-2011, 10:40 PM
Color: RED<----
Rep:15
Sweet ya I figured since it was apart I would replace anything that needed to be replaced
Old 06-09-2011, 12:45 PM
chefred112's Avatar
Rep:656
..also, get coolant and cheap oil/filter (after swap, run the cheap oil 10-15 minutes), then change to the normal oil/filter you use...
Old 06-09-2011, 01:02 PM
Color: RED<----
Rep:15
What's the purpose of that?
Old 06-09-2011, 01:04 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I'm interested to know as well.
Dillon-aka, The Little Kid
Old 06-09-2011, 02:25 PM
incubus868's Avatar
incubus868 incubus868 is offline
Vehicle: 2014 Ram
Trim Level: Larimie
Color: True Blue
incubus868 is on a distinguished road
You will have to take your water pump ect. off for the cam loosing coolant and you are gonna have a break in period for the cam hense the changing the oil flushing out shavings
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
gen 4 cam swap 1000 mile initial review autobred Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 44 05-18-2011 12:35 PM
Cam swap with mds BADBLUEHEMI Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 03-03-2011 11:55 AM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
Dodge 1500 Engine swap 1997 318 into a 1998 gourash 5.2L V8 Specific Topics 3 11-19-2009 04:10 PM
