Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 06-08-2011, 04:03 PM
want to drive want to drive is offline
Vehicle: 1990 Dodge ram D150
Trim Level: LE
Color: gray/ blue
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
want to drive is on a distinguished road
Default Fixing odometer/ pulling dash
IS it worth pulling the dash to fix the odometer and turn signal indicator (the arrow)? What all do I need to pull the dash? any help would be great.
If you are looking under my truck, you are to close to my truck
Old 06-09-2011, 08:29 AM
SPC.Brinkmeyer's Avatar
SPC.Brinkmeyer SPC.Brinkmeyer is offline
Vehicle: 1997 Ram 1500
Trim Level: SLT/Laraime
Color: Red/Silver
Rep:14
SPC.Brinkmeyer is on a distinguished road
for a 1990 D150
Cluster Removal & Installation
  1. Disconnect the negative battery cable.
  2. Remove the map light.
  3. Remove the six screws which attach the faceplate to the base panel. There is a screw below the heater-air conditioning control panel which is not visible from above.
Exploded view of the instrument cluster bezel mounting-1989-93 Pick-ups and Ramchargers
Click to Enlarge
  1. If equipped with automatic transmission, place the shift lever in its lowest position.
  2. Remove the faceplate by pulling the top edge rearward to clear the brow and pulling the bottom out, disengaging the attaching clips. If the vehicle is equipped with 4WD, disconnect the indicator wires.
  3. Remove the upper and lower steering column covers. Disconnect the shift indicator actuator cable from the steering column, if equipped.
Exploded view of the instrument cluster and switches-1989-93 Pick-ups and Ramchargers
Click to Enlarge
  1. Loosen the heater and air conditioning control and pull it out enough to clear the cluster housing.
  2. Remove the screws that retain the cluster and pull the cluster out far enough to disconnect the speedometer cable by releasing the spring clip.
  3. Remove all printed circuit board multiple connectors.
  4. Remove the cluster assembly.
  5. To remove the speedometer, remove the cluster lens, unplug the EMR timer wires from the speedometer, if equipped and remove the retaining screws.
To install:
  1. Install the speedometer if removed and connect the EMR wiring, if equipped. Position the cluster to the panel and connect the speedometer cable and multiple connectors.
  2. Push the cluster in place and install the retaining screws.
  3. Install the heater air conditioning control screws.
  4. Connect the shift indicator actuator cable and check for alignment.
  5. Install the upper and lower steering column covers.
  6. Connect the 4WD indicator if equipped, install the cluster faceplate and map light.
  7. Connect the negative battery cable.
see attached for lamp identification
ANOTHER USLESS POST BROUGHT TO YOU BY NOONE
Old 06-09-2011, 04:40 PM
Trim Level: LE
Color: gray/ blue
thanks, I could not find this info. Looks like a 3 hour project but the old truck will be worth it.
Old 06-09-2011, 05:11 PM
Color: Red/Silver
Rep:14
yea i have online chiltons so if you need something ill try and get it for ya...
Old 06-14-2014, 02:12 PM
LANDONP's Avatar
LANDONP LANDONP is offline
Vehicle: 1990 Dodge Ram D150
Color: Blue
LANDONP is on a distinguished road
SPC.BRINKMEYER, found your 2011 post for "Cluster Removal" thank you for posting that info. LANDONP
How do you pull the dash out? v10madness433 Body & Interior 23 04-06-2013 04:02 PM
Question about pulling entire dash brewman Body & Interior 3 10-15-2012 11:28 PM
pulling dash want to drive Dodge Ram General Discussion 1 06-06-2011 10:07 PM
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 10:22 PM
97 1500 Dash Replaced! brewman Dodge Ram Knowledge Base 3 02-05-2011 01:41 AM
