Confirmed: 6 speed in all 2012 models, and ram box available in all models - Page 13 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 09-22-2011, 02:19 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
Originally Posted by RadioFlyer View Post
I would imagine that it's probably because your torque curve (not peak) changed with the turbos. Never ran a turbo before so I wouldn't know what to do about that without asking around, that's weird. So what stall are you supposed to be using?
No pissing match, just trying to get real information out there. I can only share what I have experienced first hand. This is my first build using a lockup TC, everything else has been stick or non-electric automatics. I had a 2600 RPM stall TC built for me that can handle 900 FT/LBS.
Old 09-22-2011, 02:34 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Oh I know you're not, I just didn't want you to think I was. I'm old school so I have to give you extra slack being that you're more up to date than me. Is the 2600 stall for the truck you have now, the one that wouldn't flash past 2200??
Old 09-22-2011, 02:46 PM
mgh's Avatar
mgh mgh is offline
Rep:27
No, I had this one built for my current setup. I like a 2600 because this is my daily driver.
Old 09-22-2011, 02:49 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
What manufacturer is it?
Sean
Old 09-22-2011, 03:02 PM
mgh's Avatar
mgh mgh is offline
Rep:27
Custom, I have a shop close by that builds racing trans and TC and they built it for me. Billet stator, and bearing housing, tig welded fins, Alto Red Eagle lockup clutch.
Old 09-23-2011, 09:29 AM
99Ram2500 99Ram2500 is offline
Vehicle: ram 2500 1999 dodge
99Ram2500 is on a distinguished road
Maybe I'm confused then....so the 65rfe is a 545rfe except in tow/haul mode it allows the 2nd overdrive? But in normal driving mode it will not use 2nd prime upshifting?
Everyone had been posting that the 65rfe will use 2nd prime while upshifting in normal driving mode...
Don't feel lonely, I thought the same thing so I'm confused now.
As simple as possible:
When in Drive - Shifts identically to a 545RFE
When in ERS - Uses 1,2, 2nd Prime, 3,4 and Overdrive.
When in Tow/Hall - Uses 1,2, 2nd Prime,3,4 and No overdrive.
Check out Allpar.com for a breakdown of it. Its basically marketing trickery until the 8 speed is released.
Old 09-23-2011, 09:40 AM
snrusnak's Avatar
Rep:1388
Not trying to beat a dead horse or argue but....what you are describing is a 545rfe.
545rfe: when in Tow/Hall - Uses 1,2, 2nd Prime,3,4 and No overdrive.
I don't know what ERS is so can't comment....
Every other source says that the 65rfe when in drive: 1,2,2p,3,4,5
Sean
Old 09-23-2011, 10:40 AM
RadioFlyer's Avatar
Rep:146
I hate to say this, but prior to my tune my truck shifted into 5'th gear while in tow haul. It would say that it was in 5'th on the display so I know it was in 5'th. Now you've got me even more confused, lol!
Old 09-23-2011, 10:45 AM
snrusnak's Avatar
Rep:1388
Yeah but it's "5" as in 0.75:1 since the gears get rearranged......2p becomes 3, 3 becomes 4, and 4 becomes 5.
When in drive "5" is 0.67:1 and "4" is 0.75:1
Sean
Old 09-23-2011, 11:00 AM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
The trouble is there is no 2nd prime indicator on the EVIC,
so when you use it the number on the dash is not reading the gear you are actually in when using ERS mode and 2nd prime (ERS=Electronic Range Selector).
if you use 2nd prime it gets mis-labled as "3" on your evic, 3rd is mislabled 4th, Then when your trans shifts to 4th gear the evic reads "5"
You loose your last OD gear until you shift out of ERS mode.
When I used a Bully Dog GT Tuner last year, the display would read all the gears correctly and had a 2 and a "2pr" shown when in 2nd prime.
