Confirmed: 6 speed in all 2012 models, and ram box available in all models - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 09-04-2011, 12:39 PM
tmarvel tmarvel is offline
Vehicle: 2012 laramie longhorn 4x4
Trim Level: Laramie 1500 4x4
tmarvel is on a distinguished road
Is the 5'7" box available on the 2012 R/T in crew cab??
TM
Old 09-04-2011, 01:05 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
TM
Crewcab only come with the 5'7'' box, but R/T are singlecab short box only.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 09-04-2011, 07:47 PM
Rep:2929
here is what i found while searching the 2012s
1500, 2500, 3500 series
http://www.media.chrysler.com/dcxms/...1500_Specs.pdf
http://www.media.chrysler.com/dcxms/...am_1500_FA.pdf
http://www.media.chrysler.com/dcxms/...m_HD_Specs.pdf
http://www.media.chrysler.com/dcxms/..._Ram_HD_FA.pdf
Build your own
http://www.ramtrucks.com/en/lineup/i...owslider=false
Old 09-04-2011, 07:57 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Pretty cool stuff. So rambox is still only available on crew cab
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 09-04-2011, 08:13 PM
Rep:2929
This is from the ALLPAR website, it was conjecture, i'm sure
http://www.allpar.com/news/index.php...x-more-updates
Posted on May 31st, 2011 • by DaveAdmin
Reliable source MooseEater wrote that Ram will be launching its exclusive RamBox integrated storage system “for a special price” on both 5’7″ and 6’4″ beds, on 2012 regular and quad cab models. A new steering wheel will also be adopted, putting the cruise control onto the front, and a monochrome paint option will be added to Outdoorsman and Longhorn (on the latter, replacing White Gold running boards with Mopar tubular side steps and polished wheels). A Longhorn Two-Tone will still be available.
Ram will also gain new power folding trailer towing mirrors and chrome side mouldings. The ST, however, loses its bright grille, reverting to black. (Some of these features, including the RamBox and mirrors, are set up for late availability.)
Old 09-21-2011, 12:40 PM
cyberpine cyberpine is offline
Vehicle: 2012 Ram Hemi regular cab
Rep:53
cyberpine will become famous soon enough
I thought the 2012 model would offer the pentastar v6 with 8 speed transmission.. or is it they are working on it in 2012 for the 2013 model? Online Build your own 2012 is not offering the pentastar v6.
Also, anybody know if a Crew cab v6 pentaStar will be offered and with an option for a Ram box?
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 09-21-2011, 12:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
What second life said is correct from what I understand ^
The "new" 65rfe is the same as the 545rfe but reprogrammed to make use of the 2nd prime gear in normal shifting.
I wonder if the 66rfe will bolt in place in my truck? I'm sure it will bolt up....but what about programming and running correctly? I'd love to have that gear set behind my engine...
Sean
Old 09-21-2011, 12:58 PM
snrusnak's Avatar
Rep:1388
And wasnt the 54RFE just the 45RFE w/ a program I know on 3rd gen Dakotas all you needed was a TCM outta a zj or wk (I forget) and then you now had the5sp instead of the 4
Yes, so basically the 45rfe, 545rfe, and 65rfe are all the same transmission, with different programming to give either a 4, 5, or 6 speed transmission. Then like said the 66rfe is the same transmission with a different gear set(borrowed from the 68rfe of the 2500's).
Sean
Old 09-21-2011, 01:43 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Lol, I've been telling everyone this since news of the new trans coming out. The 66rfe is a 68rfe housed in a 545rfe case. So yes, it has the same bolt patern because it's the same 545rfe case. And btw, they are now listed in Chryslers parts department computers and sell for $4300 converter included if you want one. I don't know about the programing yet but I'm working on that with my dealer as we speak...I'm still waiting on answers.
Old 09-21-2011, 01:48 PM
snrusnak's Avatar
Rep:1388
Yeah I've seen it a bunch spread throughout the forum....I've just recently grasped the naming/numbering of the different transmissions and and what they all are lol. Kind of confusing since they all overlap somewhat. I would love to know if one can be made to work in my truck, the taller higher first gear would help me launch, and I could put 4.56 in with the lower OD and still get good hwy mpg. Not to mention the tighter ratios all together! I would be willing to pay for the trans if I knew I could get it to work....
Is the new 8 speed the same casing as well?
Sean
