Old 09-21-2011, 02:59 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
No, the eight speed is totally different, the casing looks more like the Nag1. I have no idea where the Nag1 design came from but the resemblence is close to the 8 speed. They're supposed to hit the market late this year but not sure because so far everything Chrysler has projected has come late or been scrapped.
Old 09-21-2011, 03:04 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If that's the case them how will it bolt up to the hemi? Or is it a totally different trans but still the same bolt pattern?
If you don't mind keep me updated with your findings on the 66rfe being used with the prior model 1500's. I know I'm the odd ball with the 4.7L but if you get it to work behind a hemi I don't see why I couldn't get it to work with my truck.
Sean
Old 09-21-2011, 03:07 PM
RadioFlyer's Avatar
Rep:146
Yeah I've seen it a bunch spread throughout the forum....I've just recently grasped the naming/numbering of the different transmissions and and what they all are lol. Kind of confusing since they all overlap somewhat. I would love to know if one can be made to work in my truck, the taller higher first gear would help me launch, and I could put 4.56 in with the lower OD and still get good hwy mpg. Not to mention the tighter ratios all together! I would be willing to pay for the trans if I knew I could get it to work....
Is the new 8 speed the same casing as well?
I would try 4.10's with your engine and that tranny unless you cam it. I would think with the stock Hemi's a 4.30 would be a good street strip gear but they don't make a 4.30 for the 9.25 rearend. You'd have to go up a notch to the 9.75 to get a 4.30. It would definately benifit your E/T and fuel milage like it is now, that's for sure.
Old 09-21-2011, 03:08 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
The 8 speed is already in the 2012 300 limited and 300s and gave it an extra 1 mpg city and 4 mpg highway over the 300 with the 5 speed. Charger should get it soon too then. It's gonna be a while for the v8 to get it though
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 09-21-2011, 03:09 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
I wouldn't bother with any factory offered trans, get a "Built" Ram 45 or ATS for under $3k with an upgraded TC
http://www.transmissionsone.com/45rf...s_from_pat.htm
http://www.atsdiesel.com/ats2/index.asp?
Old 09-21-2011, 03:10 PM
snrusnak's Avatar
Rep:1385
See I'd rather spend a few thousand on the 66rfe than $1,500 on 4.10 or 4.56 gears, as I would rather have the 66rfe with my 3.55 than my 545rfe with 4.10 or 4.56! I could still change the gears as well.
Sean
Old 09-21-2011, 03:11 PM
RadioFlyer's Avatar
Rep:146
It's a totally different trans that will have the same bolt pattern. I say will because I don't know how far into production they are or how many different bolt patterns they have to adjust to for each vehicle they plan on using it in.
Old 09-21-2011, 03:13 PM
snrusnak's Avatar
Rep:1385
He has a 4.7L Ram, not a Hemi
With all the mods planned it would have been cheaper to start with a 5.7L
He knows that, he wasn't saying I have a hemi.
I could not have bought my truck with a hemi anywhere near what I paid for it. Also, all my mods I have planned are roughly $1,500-$2,000 at most, that's pretty low budget for everything I want to do. I may not even do it all and stop at intake/exhaust/tuner for somewhere around $750 total.
And with all your mods, it would have been cheaper to start with an express
Sean
Old 09-21-2011, 03:16 PM
garner's Avatar
Rep:46
Different trans with the bolt pattern for dodge vehicles. It's pretty much the same transmission in the hyundai genesis but different gear ratios and bolt pattern
Old 09-21-2011, 03:18 PM
snrusnak's Avatar
Rep:1385
What are the gear ratios of those transmissions?
Sean
