Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 06-09-2011, 10:37 AM
Potgo's Avatar
Potgo Potgo is offline
Vehicle: 2006 Dodge Ram 1500 Sport
Trim Level: 1500 Sport
Potgo is on a distinguished road
Default Squealling Brakes
Brakes were squealling (only 25000 km on new pads and rotors) and then I noticed smoke and burning smell coming from the drivers side rear wheel. Had brakes "serviced" (whatever that involves), and replaced the drivers side rear caliper! Garage said brakes and rotors were fine! New caliper got rid of smoke and burning smell, but brakes are still squealling! They make noice when you touch them to apply but it goes away when you touch them harder to the floor! Very annoying! Any suggestions? Thank you!
Old 06-09-2011, 10:53 AM
SPC.Brinkmeyer's Avatar
SPC.Brinkmeyer SPC.Brinkmeyer is offline
Vehicle: 1997 Ram 1500
Trim Level: SLT/Laraime
Color: Red/Silver
SPC.Brinkmeyer is on a distinguished road
did you use cheap pads and rotors... could have brake dust getting trapped between your pad and rotor... try spraying between the pad and the rotor with brake klean... also if your a little mechanicly inclined you can pull the calaper off the rotor and make sure theres lube anywhere that the pad will slide on against the calaper and make sure your slide pins are lubed and arnt locking up which is what it sounds like with the smoke and everything your pad isnt getting enough space between the rotor and is constantly rubbing... if thats the case then you can warp your rotor and your pad could be crystalized on the surface causing the squeel... you could pull the pads and lightly brush the surface with a diegrinder and get rid of the crystalization on the surface.
Old 11-05-2011, 08:27 PM
MoparBandit's Avatar
MoparBandit MoparBandit is offline
Vehicle: 2010 Ram 1500 Big Horn
Color: Metallic Blue
MoparBandit is on a distinguished road
Similar situation. But it's with my front/driverside. I replaced all pads and rotors in late september. Lubed the pads, clips and caliper bushings. Pretty much step by step in the Haynes manual and yet i'll get a horrible squeal under very light pressure when coming to a halt. For the life of me I cant figure it out. Is there anything else that could be done before going down the route of new calipers?
2003 1500 HEMI QCSB Black, DSP, 33" BFG A/T's, TOW MIRROR STATUS :P, RECON Smoked Cab Lights
Squealling Brakes HEAVYDUTY Brakes 5 11-05-2011 08:56 PM
2011 outdoorsman..... No Brakes!!! clintsharley 2011 Dodge Ram Forum 41 03-09-2011 10:45 PM
My Trailer brakes have stopped working jonnydd Towing 1 01-23-2011 07:09 PM
front brakes...what are my options? strang3majik Suspension 3 10-03-2010 03:37 AM
Brakes viberate at slower (35mph) stops. steveray Suspension 2 06-05-2010 12:14 PM
= Copyright a Network Site =Ad Management by RedTyger
