TIPM same as fuse box? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 06-09-2011, 10:56 AM
CallMeClay's Avatar
CallMeClay CallMeClay is offline
Vehicle: 2009 Dodge Ram
Color: Inferno Red
CallMeClay is on a distinguished road
Default TIPM same as fuse box?
I took my truck into the dealership and they say the TIPM needs to be replaced. $900 something bux I want to be sure its not the $250 soemthing fuse box I can buy myself.
My truck is still having problems with starting and the a/c so they want to replace the TIPM. The only thing though is when the truck messes up all I have to do is move the fuse box around a little and it will work for a while until I hit a bump as if there is a loose connection somewhere. Just seems to be a fuse box problem to me.
Any ideas or know the part number so I can see if its something I can replace?
Any input is appreciated.
*Stock suspension on 305/55/20 Terra Grapplers*Flowmaster Exhaust*K&N CAI....uhh...thats about it :(
Old 06-09-2011, 12:04 PM
CallMeClay's Avatar
Color: Inferno Red
Nevermind, I check the manual and it says it is but here is another question.
If I order the part myself, would I be able to just replace the one that is in there?
Old 06-09-2011, 12:13 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Thats a steep price to me. Is that with labor or just the part?
I'm kind of a handy guy so I would definitely research doing it myself.
Old 06-09-2011, 01:11 PM
CallMeClay's Avatar
Color: Inferno Red
Im planning on replacing it myself if my warranty wont cover it. They want $900 something total for the part and install. Im looking at the part right now on some mopar part sites and its only $240.
It would be very easy to do myself but my only worry is that it might need to be flashed or something done that I can not do myslef.
Old 06-09-2011, 02:46 PM
CallMeClay's Avatar
Color: Inferno Red
UPDATE: Okay well luckily my extended warranty covered the replacement. Just incase someone else finds this via google or through the forums, here is the link to my original post about all this crap when it first started. Hope it helps someone later on.
http://www.ramforumz.com/showthread.php?t=65830
Old 06-17-2011, 07:59 AM
CallMeClay's Avatar
Color: Inferno Red
So ofcourse with my luck, the truck is screwing up again problem is not as bad as last time but doesnt want to start after sitting over night. I ran the codes and this is what it came back with. Any ideas?
U110C- no fuel level bus message
U0141- lost communication w/ front control module
U1403- Implausable fuel level signal
U110E- lost ambient temp message
Then the same codes showed but with the letters "PD" off tho the far right?
U110C (PD)
U0141 (PD)
U1403 (PD)
U110E (PD)
Old 06-17-2011, 10:45 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
If I were you, I would take it right back to the dealer since the warranty covered it the first time.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-17-2011, 03:04 PM
I agree...I'd be headed right back to the dealer. There's still a loose connection somewhere, probably from the TIPM to the front control module or the PCM. Possibly you got a faulty TIPM.
Old 06-17-2011, 04:57 PM
CallMeClay's Avatar
Color: Inferno Red
Yea Im taking it monday I guess when I get back into town. I was hoping it just might be a relay or something since its just starting that has the problem. Ill just let them try and figure it out for the 4th time lol
This is really putting a damper on my mod plans
I've heard of this problem is some other trucks. They eventually figure it out....
TIPM Electrical Issues - 2007 1500 Ram JmRam2007 Electrical 9 05-02-2012 09:44 AM
Where could I buy a replacement fuse box? CallMeClay Electrical 7 12-14-2011 03:57 PM
New Mirrors keep blowing fuse Bruno72 Electrical 2 06-28-2011 11:50 AM
Which fuse and relay to use??? Dieselkiss Electrical 2 03-10-2010 01:20 PM
Which fuse is the Accessory fuse on 6.7? iRESQu Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 12 02-06-2010 10:52 PM
