Old 06-26-2011, 05:01 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Originally Posted by CallMeClay View Post
So ofcourse with my luck, the truck is screwing up again problem is not as bad as last time but doesnt want to start after sitting over night. I ran the codes and this is what it came back with. Any ideas?
U110C- no fuel level bus message
U0141- lost communication w/ front control module
U1403- Implausable fuel level signal
U110E- lost ambient temp message
Then the same codes showed but with the letters "PD" off tho the far right?
U110C (PD)
U0141 (PD)
U1403 (PD)
U110E (PD)
This has me somewhat confused. If this is in your 2009, then it is a TIPM, then there is NO FCM (Front Control Module), unless it's internal. Prior to the TIPM, they had the IPM plus an FCM, but that all changed with the TIPM.
I think there is an issue with connector C7 on the bottom of the TIPM. Either it's not seated properly, or is damaged, or the wiring to/from it is damaged. This connector (amongst other things) includes the Can C bus communications wiring for numerous systems and the signal from the fuel sensor.
The only other thing that I believe could cause this, is damaged Can bus wiring somewhere that interrupts the communications bad enough to cause internal communications errors. But if this was the case, I'd expect a whole more issues than what you have described.
brad
Interested in one of my mods?
Old 06-28-2011, 08:55 AM
CallMeClay's Avatar
CallMeClay CallMeClay is offline
Vehicle: 2009 Dodge Ram
Color: Inferno Red
CallMeClay is on a distinguished road
Hey Brad thanks for the response!
See I was thinking it has to be one of the connections on the bottom as well because of how sensitive the problem is. I mean, if it doesnt start all I have to do is wiggle it around and it will fire right up. Before I took it in this last time it would mess up simply by hitting a bump or taking turns too fast.
I just pulled the codes and looked them up online. Maybe they are different for my truck?
I was wondering which connector I should look so thanks for that! Im going to have a look at the C7 connection when I get home and see if there is anything noticable.
*Stock suspension on 305/55/20 Terra Grapplers*Flowmaster Exhaust*K&N CAI....uhh...thats about it :(
Old 06-30-2011, 08:40 AM
CallMeClay's Avatar
Color: Inferno Red
Hey Brad, I havent been able to look at the connector yet as im still out of town but I was wondering if you knew what else ran through that connector or if you know how I can look that info up? Its just there are certain things that go wrong with the truck when messes up so if those seem to be running through that one connector I can just tell the dealership to replace the harness as well.
Thanks!
Old 07-01-2011, 10:05 AM
brad12kx's Avatar
Rep:2581
Thanks!
I don't have a detailed list specific to this connector, but it does have wiring for (not a complete list) -
Fuel Pump
Brake lamp relay
ABS power
Dynamics sensor power
Stop lamp switch
Wiper motor
Hazard swtich sense
Brake lights
All door ajar sense
Can C diagnostics
Can C IHS
Can C
Win module power
Inverter
Adjustable pedal power
Fuel level
Rear park and turn signals
Hope this helps.
brad
Old 07-01-2011, 03:16 PM
CallMeClay's Avatar
Color: Inferno Red
thanks again! I remember the ABS light coming on when it messed up but also the A/C would not blow cold so it might be another bus too?
Old 07-02-2011, 03:16 AM
brad12kx's Avatar
Rep:2581
Unfortunately, no C7 connection for anything AC related.
The AC system has connections via C1, C3, C5 and C6. Way to group them!
brad
Old 07-05-2011, 08:29 AM
CallMeClay's Avatar
Color: Inferno Red
haha wow! Is there a diagram online I might be able to send my brother showing him the connections? Im still out of town so I might have him look at it while Im gone.
Old 07-05-2011, 10:51 AM
brad12kx's Avatar
Rep:2581
Here is the wiring diagram for the TIPM.
brad
Old 07-05-2011, 11:50 AM
CallMeClay's Avatar
Color: Inferno Red
you are a saint my friend! I will forward that to him and hopfully he can look while Im gone.
Old 07-05-2011, 09:38 PM
CallMeClay's Avatar
Color: Inferno Red
so I sent it to my brother this morning and he said he didnt see anything out of the ordinary and the truck started......BUT he said the radio wouldnt turn on now
I told him to pull the fuse and disconnect the battery for a few then try again. Still nothing. Says the face comes down but nothing displays or plays through the speakers
I think I just have the worst luck with trucks lol
so now its off searching the forums for a possible solution to my REN Mygig problem
TIPM Electrical Issues - 2007 1500 Ram JmRam2007 Electrical 9 05-02-2012 10:44 AM
Where could I buy a replacement fuse box? CallMeClay Electrical 7 12-14-2011 03:57 PM
New Mirrors keep blowing fuse Bruno72 Electrical 2 06-28-2011 12:50 PM
Which fuse and relay to use??? Dieselkiss Electrical 2 03-10-2010 01:20 PM
Which fuse is the Accessory fuse on 6.7? iRESQu Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 12 02-06-2010 10:52 PM
