Old 07-05-2011, 11:18 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Thinking out loud -
Check the ground connections, especially at/near the TIPM
Check all the multipin connectors that plug into the TIPM for loose/floating pins, corrosion, bent pins, etc.
Check the wiring harnesses near the TIPM for signs of physical (mechanical) damage.
This is sounding like either of -
a) poor ground connection (emphasis on TIPM ground)
b) Can C bus problem (Open or shorted).
brad
Interested in one of my mods?
Old 07-07-2011, 07:44 AM
11Ram06Daytona 11Ram06Daytona is offline
Vehicle: 2011 Ram 2500 Mega Cab Diesel
Rep:12
11Ram06Daytona is on a distinguished road
I would agree with it sounding like a grounding problem with the amount if systems having issues. I am not familiar with how these trucks are wired, but GM uses shorting strips on the datalink wires. (im going back a few years so it might have changed) I would bet that our trucks have a similar setup.
Current Mods: Recon Smoked tail lights & 3rd Brake light
By the end of August: Recon Smoked Headlights & Roof Markers, 8K HID, 6" Fabtech Long Arm, Amp Research Steps, Fuel - Gauge 20" Wheels, Bakflip cover, H&S MaxxMini, MBRB Exhaust, 2 10" L7's 1500.1 Kicker amp.
Old 07-07-2011, 03:21 PM
CallMeClay's Avatar
CallMeClay CallMeClay is offline
Vehicle: 2009 Dodge Ram
Color: Inferno Red
CallMeClay is on a distinguished road
Ill tell my brother to check some of this stuff. Its frustrating im not there to look at this all myself. I posted about the Mygig on a fourm thats dedicated to them and it looks like it dead Might have to just buy one
*Stock suspension on 305/55/20 Terra Grapplers*Flowmaster Exhaust*K&N CAI....uhh...thats about it :(
Old 07-07-2011, 10:59 PM
brad12kx's Avatar
Rep:2581
It's a possibility, but I wouldn't rush in getting a replacement until the TIPM issue is solved. I've learned over the years to fix the computer issues first, then see if anything else needs repair. Often a TIPM/computer issue will create 'phantom' issues.
brad
Old 07-08-2011, 08:12 AM
CallMeClay's Avatar
Color: Inferno Red
Good point Brad, maybe its something with in the TIPM causing it to screw up. I should be home Wed. so hopefully I can look at her soon and take her down to the dealership.
Since they have already replaced the TIPM once should I tell them to check the connecting harnesses as well on the bottom? Is there a way for them to check them and make sure they are doing what they are supposed to be doing?
Old 07-08-2011, 10:36 AM
brad12kx's Avatar
Rep:2581
Yes and No.
Being a computer and tied in with more computers, allows them to run some pretty decent diagnostics, but if a final driver is bad, there is not way to determine if the final output is there or not. This is where the tech comes in. He can get the diagnostics info that tells him the output is on and working, and he can then check with a meter to verify that it actually exists.
It was easy to make that sound easy, however sometimes this can be a rather laborious task.
brad
Old 07-22-2011, 01:06 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
My TIPM was replaced on my last 2011 they said it was defective and it was backordered for anwhile. It was not sending power to my AC compressor. Call Chrysler they should replace it for free. They know it has problems.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 07-26-2011, 08:28 AM
CallMeClay's Avatar
Color: Inferno Red
thanks for the reply gynst2. Hate to hear that anyone else has had a problem with their TIPM. Im assuming all is well now?
I finally got back in town but had my brother take it up for me last monday....its still there. I told them to check the harnesses on the bottom of the TIPM and check the radio since it just stopped working. They found a bad connection with one of the harnesses and took full blame for the radio messing up (?) so they arent charging me for any of it and they are covering my rental for a week. Im hoping this is the last problem I have with the TIPM, nothing worse than Texas heat and no A/C!
Old 09-03-2011, 10:55 AM
Capt 0verkill's Avatar
Capt 0verkill Capt 0verkill is offline
Vehicle: 2007 Dodge Ram
Capt 0verkill is on a distinguished road
Default My TIPM Problems
I bought my 2007 Ram July 5th. Around mid August my Serv 4WD Light came on while I was driving down the highway. I was only a mile from my destination, so when I stopped I re-started and light did not come back on. A week later came on 3 times in one day and it is not a Service Interval Light.
Took it to the Dealership and They had my truck for 3 days diagnosing the problem. According to the dealer the tech was working with an Engineer on my Serv 4WD indicator and other problems??? According to the dealer's service rep the engineer wanted to do exhaustive testing before he would say it was TIPM. The Service Mgr pretty much told me the first day that the tech was certain it would be the TIPM. Also, my Transfer Case Actuator does need replaced.
So next week I have to take my truck back because an Engineer/Inspector will be onsite and wants to look it over and go over the results. Oh and the parts are on back order.
Just happy it is covered under my extended warranty!!!
Old 09-03-2011, 11:40 AM
brad12kx's Avatar
Rep:2581
I'm guessing the transfer case actuator was the cause of the 'Service 4wd' light, and the 'other problems' are the result of them finding some pending codes that they found while scanning it. It sounds to me like you may have a good dealer. Often they will just clear the codes and send you on your way, so if this is the case with yours, I give koodo's to the service department.
brad
TIPM Electrical Issues - 2007 1500 Ram JmRam2007 Electrical 9 05-02-2012 10:44 AM
Where could I buy a replacement fuse box? CallMeClay Electrical 7 12-14-2011 03:57 PM
New Mirrors keep blowing fuse Bruno72 Electrical 2 06-28-2011 12:50 PM
Which fuse and relay to use??? Dieselkiss Electrical 2 03-10-2010 01:20 PM
Which fuse is the Accessory fuse on 6.7? iRESQu Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 12 02-06-2010 10:52 PM
