View Poll Results: How should I level my Ram?
Raise the front 62 46.27%
Drop the back 55 41.04%
Just leave it stock 17 12.69%
Voters: 134. You may not vote on this poll
Old 06-09-2011, 01:00 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Default Raise the front or drop the back?
So I've been doing some reading about leveling my truck and want your opinions and thoughts.
I have a 2WD 2010 Ram that I consider a street machine. I like the over all height of the stock tires but do plan to get custom rims (prob 18's) with a lower profile tire.
I see that I can raise the front with kits around $100 - 150. Pro's seem to be that it is cost effective and allow for larger wheels. Con's seem to be that some kits are hard to install and they don't 100% level the truck.
I see that I can drop the back for about $350 - 370. Pro's seem to be that some kits give you stiffer suspension that won't sag under heavier loads and the ride quality suffers little. Con's would be that you could not increase the size of your wheels.
So what an I missing? should I raise the front or drop the back and why?
Old 06-09-2011, 04:35 PM
SPC.Brinkmeyer's Avatar
SPC.Brinkmeyer SPC.Brinkmeyer is offline
Vehicle: 1997 Ram 1500
Trim Level: SLT/Laraime
Color: Red/Silver
Rep:14
SPC.Brinkmeyer is on a distinguished road
im always for going up.. hell i got 35s on my ram with a level kit and BL that were on it when i got it and i want to eventualy fit 40s
ANOTHER USLESS POST BROUGHT TO YOU BY NOONE
Old 06-10-2011, 06:29 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Honestly I like the way it looks stock.
Old 09-26-2011, 02:50 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If you can get your hands on a cheap used set of rear springs of a single cab you can cut them safely. They have tighter wound coils at the top compared to the quad cabs, that are safe to cut and you can cut as much as about 2" and still be safe to ride on them. Ride quality is basically unchanged, although you probably will lose a few hundred lbs (at most) carrying capacity. This would only cost you the price of the used springs (I bought mine from a guy with an RT that bought a lowering kit, he only charged me shipping, I think it was like $15....he was from this forum).
Sean
Old 09-26-2011, 03:04 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
The rear coils on an R/T must be different then
I put a Ground Force 2/3 Drop on my RCSB 4x4 and the stock rear coils are standard, only the new replacement GF coils are progressive.
Stock left, progressive right...
I love my leveled 4x4, Front only dropped about 1.5", rear a bit over 3.5" and still room for large wheels/tires ...currently running 305/50R20's with my 2/3 Drop.
The ride quality is 10x better than stock, and so is the handling when I toss her aggressively into a tight corner....has never bottomed out.
before/after pic's
Old 09-26-2011, 03:07 PM
snrusnak's Avatar
Rep:1385
Good point. This could be a 4x4 vs 4x2 thing though also(meaning that it may be possible that a 4x2 single cab has progressive coils...maybe?). If one were to try to buy springs to cut they'd have to see them before buying them. I can say for sure the RT's will work as that's what I bought.
Sean
Old 09-26-2011, 03:41 PM
Rep:554
The biggest issue I have with cutting coils is they are no longer engineered to perform properly with your 5 link suspension.
Not only is it unsafe and unstable it may get you in trouble with an insurance company if you cause a wreck and they find you "hacked" a key suspension component.
The reason Ground Force kits are the most expensive is because they "Engineer" them with specific designed progressive coils.
Here's a stock 2wd rear coil, note a very limited number of wraps
Interesting read on http://www.allpar.com/model/ram/2009-ram.html
The new spring layout shows the attention to details and vehicle dynamics that the people at "JTE" [Jeep-Truck Engineering] are famous for. While odd looking with its offset springs to the layman, this design shows attention to the fundamentals of vehicle dynamics.
In 1967, GM used a 3 link (as opposed to the new Ram's 5 link) coil sprung suspension. The result was that the vehicle had a very comfortable ride when empty (industry leading, in fact), but when any load was placed in the pickup bed, the vehicle became unstable and sloppy handling. This result almost sank the new trucks before they were even out of the gate (it was deleted in favor of a conventional Hotchkiss shortly thereafter). The new Ram is the first U.S. volume built pickup truck since that time to attempt to use coil springs as its primary suspension system.
The pitch of the springs shown in the accompanying graphic show how the springs are canted and "bent" at the BPL position (BPL=Body Part Loaded- this means a loading of 2 each 150 lb passengers, full fluids, and 1/2 payload all combined to be the base point of design for the vehicle) to allow the reactions to motion of the ground contact patch ("where the rubber meets the road", to use an old marketing phrase of another company) to be efficiently controlled and isolated from disturbing the ride quality and stability of the vehicle.
The UCA (Upper Control Arm) links appear to be splayed outward at the frame attachment points, providing a lateral stability to the system that, in conjunction with the track bar (or "panhard rod") keeps the lateral shift of the axle, between jounce and rebound (maximum travel up and maximum travel down- NOT "bounce" and "droop"), to the minimum arc possible. Due to the over-constrained system (more about this in a moment) the axle will travel laterally in the vehicle, through an arc of approximately 2" total, left to right. The positioning of the track bar ensures that the travel will also be split evenly from jounce to rebound, minimizing the dreaded "head toss" so prevalent in the Jeep XJ (Cherokee SUV), MJ (Comanche pickup), and early ZJs.
The side view angularity between the UCA and LCA (Lower Control Arm) indicates a long instant center, a theoretical point in space ahead of the axle, that controls the fore and aft arc the axle travels through as it goes from jounce to rebound. By having a long instant center, you ensure the axle does not change the wheelbase a great deal, affecting braking distances and geometry and upsetting the transient dynamics of handling in an emergency lane change.
Old 09-26-2011, 03:51 PM
snrusnak's Avatar
Rep:1385
And that's a single cab? If so then looks like cutting an RT spring is really the only safe way to go(if you're even comfortable with that).
Sean
Old 10-03-2011, 06:57 AM
lficke's Avatar
lficke lficke is offline
Vehicle: 2005 Dodge Ram 1500 2wd
Trim Level: SLT-ThunderRoad
lficke is on a distinguished road
Too much rake - have to raise the front!!!
2005 Ram 1500 ThunderRoad 2wd, 5.7 Hemi, 7in lift, Nitto 305/55/20 ,Tonneau Cvr, Vent Visors,Tint
Old 10-03-2011, 03:19 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
2wd = lower rear
McG 44050MGY Spindle Drop Kit 09 RT RAM Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 12 08-12-2010 04:28 PM
Have a front diff question ScatPak07 Suspension 5 03-03-2010 09:25 PM
Front end noise bkirchner 4.7L PowerTech V8 Specific Topics 3 02-02-2009 02:43 PM
Went from a 2-4 drop and lifted 4' SlIcKSRT Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 01-27-2009 10:58 PM
the front end or back end? that is the question! zacotaco Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 9 12-27-2008 04:12 PM
