Old 06-09-2011, 01:12 PM
readeth readeth is offline
Vehicle: 2011 Outdoorsman
readeth is on a distinguished road
Default Lift question. Need expert advice
So I'm researching putting 35's on my truck. I just put a leveling kit on my 11' 1500 and I've been told that I can put a 35 inch tire in 60r/20 on my truck but that it will rub the bumper. I've also been told there is a spacer that can be used to fix this problem?? can some one shed some light onto this question and if i should be doing this. will i run into any problems with this setup??
i'm a newb. with lifting and such so be honest..
thanks in advance!!!
Old 06-09-2011, 01:30 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Well personally I don't like the look of a stuffed 35 with just a leveling kit. I think a nice beefy 33x12.5 looks perfect. If you were to fit a 35x12.5 you would have to either get after market wheels with a offest of at least -12 or a set of wheel spacers. In the long run I would go with aftermarket wheels if you were to get 35s but if I were you I would go with 33s. Just my .02!
Dillon-aka, The Little Kid
Old 06-09-2011, 07:44 PM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
I think most level kits say the max size is 33. Even some of the 4inch lifts say max size is only 34.5. Your trying to stuff those bad boys in and I am sure if you hit a big enough bump you will feel that tire rubbing. Not worth messing your truck up.
Old 06-09-2011, 08:28 PM
gunnycarmon's Avatar
gunnycarmon gunnycarmon is offline
Vehicle: 2011 Dodge Ram Long Horn Lari
Trim Level: Laramie Long Horn
Color: Black/Gold
gunnycarmon is on a distinguished road
Guys,
This truck comes with 275/60R20's, which if you do the math are 33.1" already, I too have seen the lifts that offer the 35's with a 2.5" lift. Something to consider is to go with a 1.5 Body lift and I think you will clear those 35's with ease. Pro Comp offers a full 6" kit as well and claims you can run 37/12.50's with that lift. Just go to a good shop and you will be fine.
Old 06-10-2011, 04:28 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
I have 37's on my 1500 with a BDS 6" lift. I had them on there before I added anything to the kit and it didn't rub.You can put 35's on there with just a level but you will need spacers or after market wheels "as stated above" to push your rims out from your steering arms. If you don't they will rub like crazy.The 35's will be stuffed in there too. Pics after you get it all installed .
Old 06-10-2011, 11:21 AM
yes the stock tires are a wee bit over 33". I saw in the mopar catolauge that it said with the leveling kit 35's would fit.. decisions, decisions... lol
Old 06-13-2011, 01:54 PM
Greg50Lt's Avatar
Greg50Lt Greg50Lt is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Trim Level: Sprot
Rep:20
Greg50Lt is on a distinguished road
I was going to level mine but decided to just wait and do a 4in lift with the bilstein shocks added and while Im doign the lift just get the rims and tires.
OE: Nav/Alpine, Backup cam, brake controller, side steps Aftermarket:Bedliner, Tonnopro bed cover, Windows 20% Tails and Cab light tinted, 18in Magnaflow, Black Fuel Hostage 20x9 trail Grapplers 295-60R20, TGC 2.5 front spacer .75 rear, Billet fuel door
Old 06-16-2011, 07:37 AM
Edokdyshi's Avatar
Edokdyshi Edokdyshi is offline
Vehicle: 2012 Ram 1500
Rep:143
Edokdyshi will become famous soon enoughEdokdyshi will become famous soon enough
On my 2010 2500, 35's do not fit on my truck with a level kit. They end up rubbing on the backside of the wheel well when I make turns. I don't know if this is gonna hold true for the 1500's or not. Just for reference I used 20x9 rims with a 4.5" backspace and a -12 offset.
18" Magnaflow muffler, 5% tint all around, multiple blacked out parts, de-badged, Westin Bull Bar, K.C. Long Range SlimLites
lift question cjg07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 06-24-2011 10:17 PM
Another lift Question Torq89 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 04-29-2011 01:25 AM
lift question cjg07 Suspension 1 03-30-2011 07:02 AM
Spindle Lift Question!! goodjohnson Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 01-27-2011 12:46 PM
Lift Question Cap10crch Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 04-26-2010 10:14 AM
