Old 06-09-2011, 01:59 PM
69speeder69's Avatar
69speeder69 69speeder69 is offline
Vehicle: 2001 Dodge Ram
Trim Level: Laramie SLT
Rep:18
69speeder69 is on a distinguished road
Default Ticking up front
The last week or so I have been having a some what loud ticking from what seems to be coming from the front left. At first I thought this was because of the used steering gear box that i put in because it seemed to start about the same time as me replacing it. And i could only notice it on turns. So I replaced the gear box and still am hearing it. Only now I am also hearing it going straight. But only at speeds between 10 and 30 mph. Anything higher than that I dont hear it as well as slower. I am assuming wheel bearing. But can anybody shine a little more light on this issue for me.
Old 06-09-2011, 11:51 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
How about using the link in my SIG to jump over to our Red Ram Group and join us.
Old 08-14-2011, 02:26 PM
00dodge1500's Avatar
00dodge1500 00dodge1500 is offline
Vehicle: 2000 Dodge Ram 1500
Trim Level: Off-Road
00dodge1500 is on a distinguished road
hi, if you havent figured out the problem yet, it is probably a u joint out. mine did the same thing a couple months ago
Old 08-14-2011, 03:45 PM
Terryserf's Avatar
Terryserf Terryserf is offline
Vehicle: 2001 Dodge Ram 1500 Quad LWB
Trim Level: Laramie SLT 4WD
Terryserf is on a distinguished road
I had the same noise, but on the right front. the clacking sped up and slowed down in unison with the speed of the wheel. It was in fact the universal joint. Replaced the left and right side at the same time. Solved the problem. good luck, T.
If I don't see you in the future..... I'll see you in the pasture....
Old 08-20-2011, 01:28 PM
MoparGuy86's Avatar
MoparGuy86 MoparGuy86 is offline
Vehicle: 1985 Dodge D250 5.9 2WD
Color: Faded Gray
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
MoparGuy86 is on a distinguished road
I'm going to have to agree. I have replaced about 3 of them (Soon to be 4 ) on 2 rams. once you do it a few times, its easy and you can knock it out in no time.
Old 08-21-2011, 11:11 PM
24CTGoldie 24CTGoldie is offline
Color: Maroon
24CTGoldie is on a distinguished road
I agree that it's a u-joint as well. Just replaced the right front on mine. Took about an hour total.
Old 08-22-2011, 06:39 AM
2kram 2kram is offline
Vehicle: 2000 ram 1500
2kram is on a distinguished road
Agree with all about u-joint. when replacing get the ones that you can grease thru the zerk, they do last longer....
Old 08-25-2011, 11:21 PM
Rep:18
Sorry meant to post sooner. And you are all correct. It in fact was the u joint
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
instructions to enable front seat video in motion partypooper 2010 Dodge Ram Forum 20 08-05-2011 06:14 PM
Front Driveline Question herc 2011 Dodge Ram Forum 7 04-19-2011 04:35 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 10:48 PM
Charlie again ! Re prev post front end howl charlie Cummins Diesel Specific Topics 2 01-20-2010 08:26 PM
