01 Ram Quad 4x4 - Morning Starting Issues - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 06-10-2011, 11:09 AM
Paffer Paffer is offline
Vehicle: 2001 Dodge Ram
Trim Level: Quad Cab
Paffer is on a distinguished road
Default 01 Ram Quad 4x4 - Morning Starting Issues
Hello All,
I have an 01 Quad Cab 4x4 Sport with the 5.9L engine. If the truck sits without being started (overnight) I have to turn the key multiple times to engage the starter. The problem seems to be getting worse, taking longer to start.
I have had the battery, alternator and starter checked at the local Autozone. No issues
I have placed a charger on the battery overnight and still had the same problem. I can hear the fuel pump kick in but that's the only sound until the lucky key turn that starts the engine.
I'm at the ignition switch, solenoid, relay level and looking for some advise on how to proceed. Should I try to jump from battery to starter solenoid with the key in the on position and work my way back or should I start at the ignition switch or some other place? Any advise would be highly appreciated.
Also, is there a way to check codes without a code reader. Not sure these would help but couldn;t hurt. If I hold the OD trip button in on my wife's minvan I can get some codes.
Thanks,
Bill
Old 06-10-2011, 11:17 AM
SPC.Brinkmeyer's Avatar
SPC.Brinkmeyer SPC.Brinkmeyer is offline
Vehicle: 1997 Ram 1500
Trim Level: SLT/Laraime
Color: Red/Silver
Rep:14
SPC.Brinkmeyer is on a distinguished road
http://dakotaforumz.com/showthread.php?t=867
To check your engine codes:
Turn the key to ON (not start), OFF, ON, OFF, ON and leave it there. If you look in the odometer window the codes will flash any code(s) with a small delay between each result. Each code should be in a P#### format, and will say PDONE when completed - turn your key to OFF and remove. Use the OBD code list to determine what problem the computer detected.
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
if you pull a code like i do without the light being on from time to time the code list is in above link
ANOTHER USLESS POST BROUGHT TO YOU BY NOONE
Old 06-19-2011, 12:35 AM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
sounds like you have a bad ignition signal wire. possibly coroded. test the wire going from the ignition to the starter.
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 06-28-2011, 09:38 PM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
Check your starter relay it may be going bad and having trouble energizing. Herei is the procedure straight from the FSM.DIAGNOSIS AND TESTING - STARTER RELAY
The starter relay (Fig. 13) is located in Power Distribution
Center (PDC). Refer to PDC cover for relay
identification and location. For complete starter relay
wiring circuit diagrams, refer to 8, Wiring Diagrams.
(1) Remove starter relay from PDC.
(2) A relay in de-energized position should have
continuity between terminals 87A and 30, and no
continuity between terminals 87 and 30. If OK, go to
Step 3. If not OK, replace faulty relay.
(3) Resistance between terminals 85 and 86 (electromagnet)
should be 75 6 5 ohms. If OK, go to Step
4. If not OK, replace faulty relay.
(4) Connect 12V battery to terminals 85 and 86.
There should now be continuity between terminals
30 and 87, and no continuity between terminals 87A
and 30. If OK, perform Relay Circuit Test that follows.
Old 06-29-2011, 01:43 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
A slightly faster way to check if the relay is faulty, is to swap it with either the trailer or blower relays. They are right beside the start relay, and look the same.
brad
Interested in one of my mods?
Old 07-02-2011, 02:02 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Check the connection at the starter. The terminal could be corroded.
Help! desperate, 2003 dodge starting issues!! janruss1999 Cummins Diesel Specific Topics 12 04-30-2012 02:35 AM
06 Quad Cab 4x4 Rotor issues bluewingjb LD RAM - General Discussion 2 09-15-2010 09:25 AM
A few issues? Ruffian11 5.7L V8 Specific Topics 3 09-05-2010 11:08 AM
07 quad cab vs a a chevy moparmike07 Kills and More Kills 12 09-02-2010 04:31 PM
Saw a quad cab wrecked this morning Kens04 LD RAM - General Discussion 9 02-02-2010 03:58 AM
