Old 06-10-2011, 12:58 PM
sylster's Avatar
sylster sylster is offline
Vehicle: 2011 Dodge Ram sport
Color: hunter green
Rep:19
sylster is on a distinguished road
Send a message via MSN to sylster
Default First tow
Well....I went and got my travel trailer out of storage. I have to admit that I hate towing but my wife won't let me get rid of the trailer. I was pleasantly surprised on how well it all went....aside from that yard being a mud pit. Love the 4x4 or the trailer AND my truck would still be there.
I know it's not a heavy trailer....it's just an 21' Ultra lite Okanagan (2900lbs) dry but should I be using the tow/haul button when I tow it.....Going on a 6000+kms (3700+ miles) trip this summer and curious.
....a pic for you pic hounds on here hahaha
Sylster
Old 06-10-2011, 01:54 PM
jk4.7 jk4.7 is offline
Vehicle: 2002 dodge ram
Trim Level: base
Color: silver
jk4.7 is on a distinguished road
yes and no on the tow button its made to turn ur overdrive off and u loose a gear witch will kill ur mileage so when on falt lands as far ass the eye can see id leave it off but in the hills turn it on .just for fyi the button also makes the pressure in the tranns higher so it shift a little rougher but nothing to worrie about
Old 06-10-2011, 02:01 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
I towed my popup to the beach and back with tow haul about 500miles and got 15 mpg with tow haul on...
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 06-10-2011, 04:14 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
It really depends on conditions. I tow a 6x12 cargo trailer that weighs just a bit more than yours does when loaded. On hills or into a good head wind I have it in Tow/Haul mode. On fairly flat terrain I leave the Tow/Haul off, the cruise control on and she tows just fine. With the distance you're traveling I suspect you will run into both conditions. Good Luck
Old 06-11-2011, 08:34 PM
Bigboyky Bigboyky is offline
Vehicle: 2011 Ram 1500
Trim Level: Laramie Monotone
Color: Mineral Grey Mettalic
Bigboyky is on a distinguished road
I'd leave it off. Listen to your truck..... if the tranny starts hunting for gears then tow/haul. The truck will let you know. Don't run it with the transmission hunting for the right gear, you'll burn it up. Personally I would think the truck will handle 2900lbs. with no problem.
Old 06-12-2011, 07:52 PM
sylster's Avatar
Color: hunter green
Rep:19
If my minivan pulled it with relative ease....should be a breeze with this truck.....and to boot mileage should be better ....that minivan barely got 375kms on 100$ fill up when towing.
Sylster
Old 07-03-2011, 08:38 PM
sylster's Avatar
Color: hunter green
Rep:19
Well, Well, Well.....I AM NOT IMPRESSED!....or maybe need guidance. My wife went on a 440 miles road trip....pulling our trailer....2700lbs and with water and gear + water....about 3200lbs.....well...the truck averaged 25.4L/100 or 9.6miles/US gallon.....@ 60MPH she said she was on tow/haul all the way....THAT IS SOOOOO BAD!.....I don't think that she needed the tow/haul but I wasn't there...so it was safer....
My upcoming cross country road trip is gonna ruin me if this is actual mileage.....
Feedback please
Old 07-03-2011, 09:19 PM
Sounds low but again ambient and driving conditions tend to dictate mileage. How many hills? How steep of grades? What was the temperature? Running with or against the wind? How fast was she driving?
If it's flat, and no real hills to pull, then leave it in O/D. Tow haul is used when you feel the truck hunting for a gear and when you have some hills in your route.
Good luck!
Old 07-03-2011, 09:33 PM
Rep:220
Well you definitely don't need Tow/Haul most of the time for that weight, possibly in the hills but that's it. That is a good part of what is killing your mileage but even that sounds low.
Old 07-03-2011, 10:22 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
sylster, how many km's on the truck? Your mileage will take a big jump after 15,000km's. My last truck jumped huge after 15k. I'm not quite there with the Ram yet but I'm getting close. Will report after the magic number.
Big Red my old 2011 Sport
