Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-11-2011, 04:59 AM
wilkinson wilkinson is offline
Vehicle: 1994 Dodge Ram 2500
wilkinson is on a distinguished road
Exclamation Cannot remove pinion from housing!
Ok, I Recently found out my pinion seal was not operational anymore and also the front pinion bearing. While inspecting this problem, I opened up the cover to see that the carrier was susbtantially ground in to by the pinion. So I decided that it was time for a complete rear end rebuild. And since I'm going all out, why not go with 4:56's? It is after all strictly for coal mining and mudding. So as the disassemble takes places, everything is going smoothly until I get to the pinion. It just will not come out. I'm
Under the assumption that the front bearing got so hot without any lubrication that it has seized on to the pinion shaft and will not allow it to come out. I have a fear of cutting into the housing if I try to cut the bearing so the pinion shaft will be allowed to be knocked out the back. What do I do? Or am I just doing something wrong and over looked a step? Please help!
Old 06-11-2011, 05:03 AM
Oh, this is a 1994 5.9L 4WD, 2500.
pinion bearing, rear differential, ring and pinion, stuck pinion
Removal of transmission MrDodge300 5.2L V8 Specific Topics 2 01-16-2011 02:49 PM
Filler Neck Bulletin Shreve T 2010 Dodge Ram Forum 3 11-09-2010 08:27 AM
My RAM 6,000 mile review..... DodgeRamMan71 2010 Dodge Ram Forum 29 11-04-2010 05:33 PM
Good Price for Complete Used Rear-end? marlin336 Suspension 7 03-09-2010 09:58 PM
Rear end confusion dirtsurferus Suspension 6 12-30-2009 08:25 AM
