Old 06-12-2011, 09:34 AM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
Default Back up camera
looking to get after market back up camera installed
Which would be the best unit and best looking in dash install without removing existing radio (satellite radio with u connect - no screen or GPS)
Old 06-12-2011, 04:52 PM
Well, you need a screen. One of the cool options I have seen is that you can get rear view mirrors with screens in them and when you activate the camera, on goes the screen.
They are pretty small, though, which is why most factory systems use this feature with a double din head unit and a 7" screen.
Almost any camera out there would work. A lot of folks like the kits that mount on the license place area. They look like a standard plate ring and are pretty subtle. This is a good place to mount it if you are worried about what is immediately behind you below your vision line, like little kids on trikes and such. It's also great for backing towards a low wall, fence or other obstruction.
So, if you don't wanna go with a DD head unit, sticking with your stock unit, then I'd look into the rear view mirror / screen or an independent screen mounted elsewhere, such as in your center console.
Old 06-12-2011, 05:57 PM
Rep:2657
I wonder if a flip up screen could fit under where the climate controls are, where it reads RAM?
or get a suction mount 4 inch monitor to mount on the floor console IF you have one,
or a bean bag mount for a 4" monitor & set it up in the sunglass tray on top of the dash
If you have a Ram with NO floor console, you can put a monitor down in or near the bottom of the dash, cup holder/ash tray area
[IMG]
Old 06-12-2011, 10:01 PM
Boubou's Avatar
Rep:54
the interior looks like this:
http://www.google.ca/imgres?imgurl=h...w=1680&bih=827
so something to dock into that little dodge tray above the radio (think it should pop out or something) would look best I think
Old 06-13-2011, 03:07 AM
Rep:2657
the rubber tray just lifts out, 2 screws are under it, they are usually removed when you need to get access to your radio, other screws have to be removed from other places to do that completely
there may be a little cut out to run a wire or 2 through it for a small monitor
New Muffler = Loss of Power??? BigOrange Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 15 07-05-2014 01:27 AM
Back Up Camera Foggy Rugged Brown 2010 Dodge Ram Forum 4 12-07-2010 06:09 PM
Added Magnaflow Cat back and lost some low end! Thetolleyman Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 10 11-23-2010 04:34 PM
Front Parkikng Camera Location bugums1 Electrical 1 08-29-2010 12:23 PM
Rear Camera Confusion... CustomShirts 2010 Dodge Ram Forum 21 05-12-2010 01:13 PM
