Old 06-12-2011, 03:28 PM
NYR99's Avatar
NYR99 NYR99 is offline
Vehicle: 2011 Ram 1500
Trim Level: Sport 4X4
Color: Mineral Gray Metallic
NYR99 is on a distinguished road
Default Stake Holes
How do I go about using the front stake holes? The covers appears to be sealed on. Do I just use a razor blade? On my Tundra they just popped out.
Old 06-12-2011, 03:37 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
looks like you're gonna have to do some cutting...prolly easier to pop the side rails off and cut them out, unless you want to etch your paint with the blade.
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
Old 06-12-2011, 04:40 PM
JBOF79 JBOF79 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: SLT Big Horn
Color: Blue
Rep:15
JBOF79 is on a distinguished road
Yea the best way is to take the liner sides off that's what i did and used a dremel
Old 06-12-2011, 09:47 PM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
I haven't cut those out of mine but the trick I use when cutting that kind of plastic is this. Clamp a blade from a safety knife into a vise grips (bigger is better). Heat the blade using torch of some kind until it is cherry red. Then the blade will slice through the plastic like butter. Repeat the heating when needed.
PS. The blade will be worthless for cutting after this.
Hope that helps
Old 06-12-2011, 10:12 PM
Rep:2705
look under your bed rails for fasteners, it may be that the bed rails are stuck on with double sided tape
the metal part under the plastic covers is very uneven, several recessed areas
if i were to take my plastic covers off, i would replace them with metal pieces with the holes already in them
you can get many different brands, here are a few
http://www.partstrain.com/store/inde...d%20Rail%20Cap
Old 06-12-2011, 10:50 PM
NYR99's Avatar
The plastic seems to be pretty thin. I think just a regular razor should be fine, I do like the heat trick though. I tried taking off the bed rail but it is on there pretty good and I dont want to break anything. I need access to the hole because I am installing this:
http://www.autoanything.com/bed-caps...A5953A0A0.aspx
Thanks for all the responses guys. I also have some Westin Platinum oval step-bars and AVS in-channel vent visors coming as well. Can't wait! I will post pictures when everything is installed.
Old 01-03-2012, 04:05 PM
DonJohnny's Avatar
DonJohnny DonJohnny is offline
Vehicle: Ram 1500
Trim Level: Outdoorsman
Color: White/grey
DonJohnny is on a distinguished road
i too am installing my putco 3" boss bars on the top of the box. i found this thread full of inforamtion and i am opting to use the heated blade trick., will post pics when done
I work in Sales at a Dodge Jeep Ram dealer in BC Canada
Check out my PinkBike profile
Old 01-03-2012, 05:48 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
when I got my ram one of the top rails was cracked.. when they took it off to replace it the unit cracked in to 3 pieces.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 01-03-2012, 11:34 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
Look under the bed rail and find the clips to release them.
While you have them off, think about painting them to match the truck. What a clean look! Doesn't look like an add on to cover a mistake!!!
That was part of my deal when I bought my truck.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 01-05-2012, 10:25 PM
nisbitch's Avatar
nisbitch nisbitch is offline
Vehicle: 2013 Dodge Ram Sport CC
nisbitch is on a distinguished road
I know when I cut out my front stake holes, the marks on the plastic did not match where the holes were. So I'd be careful about taking the plastic off and cutting it assuming that the holes match the marks. Maybe mine was one of a kind though.
Mopar T-Shifter - Bakflip G2 - Weathertech Floor Mats - HBS 2.5" Leveling Kit - Front 20% Tint
Stake Pocket Cover skirk55 2011 Dodge Ram Forum 1 03-14-2011 08:37 PM
Holes in Wheel wells harleysarge 2010 Dodge Ram Forum 15 11-16-2010 02:29 PM
Bed Rail Stake Pockets Jiggerk Dodge Ram General Discussion 1 09-22-2010 10:06 AM
Tape on holes in rockers? RJG 2010 Dodge Ram Forum 8 06-12-2010 02:29 AM
Holes in the bumper HotWheels 2010 Dodge Ram Forum 12 06-06-2010 10:51 PM
