Old 06-12-2011, 03:36 PM
BABY TONY BABY TONY is offline
Vehicle: 2003 ram 3500
Trim Level: larami
BABY TONY is on a distinguished road
Default A/c just stopped!!!
3 days ago i replaced my a/c compressor, dryer, expansion valve, flushed the evap., and condensor, took the truck to local mech. Shop and had vac. Pulled down and new pag oil and freon added. Yesterday a/c started blowing ambient temp. Air. The clutch is spinning with the compressor, a/c lights on the dash work, fuses are good and i can swap to heat and it blows hot air then. Any ideas what the problem could be??
Old 06-12-2011, 05:20 PM
Possibly a leak and all your coolant has escaped. I'd pressure test the system.
Old 06-12-2011, 06:33 PM
Trim Level: larami
I used a screwdriver to see if any freon came out, got some out of the hi side, and i also tried to add a can just in case there was a leak, the system would not take the freon
Old 06-15-2011, 11:13 PM
Trim Level: larami
Well i took the truck back to the local mechanic and he checked my truck out, found the seals had blown out of the new compressor i had just installed : (!!! Thankfully napa replaced the reman compressor with a brand new one, a/c works great again !!
Old 06-16-2011, 07:47 PM
kwatson's Avatar
kwatson kwatson is offline
Vehicle: 2006 Dodge Ram 1500 SLT QC 4X4
Trim Level: SLT Quad Cab
Rep:24
kwatson is on a distinguished road
Boy Napa seems to have a problem with their remanufactured parts blowing seals! I went through 3 power steering pumps and now 8,000 miles later, I have to replace the pump again. Will not use a reman pump again. Maybe one from a wrecking yard off a low mileage truck.
Kurt Watson - Deer Park, WA
2006 Dodge Ram 1500 SLT 4X4 quad cab
heater stopped suddenly grungybob Heating & Cooling 5 02-13-2011 11:42 AM
Help! Oil Pressure Dropped, Engine Stopped. Don't know what it could be. MacD V6 Specific Topics 5 01-27-2011 09:22 AM
When the music stopped BlueJet Military 5 05-22-2010 01:39 AM
Three stock speakers stopped working!? Silver05Ram Custom Dodge Ram Interior Modifications - Custom Audio / Video 7 02-09-2010 11:11 AM
Ezcorpion Stopped by the house for Speedo Rings Mecha Advanced Automotive Concepts - AACstyle - Dodge Ram Accessories! 3 07-23-2009 12:27 PM
