Old 06-12-2011, 08:05 PM
estoltz estoltz is offline
Vehicle: 2011 Dodge Ram 1500 5.7 4x4
estoltz is on a distinguished road
Default My First Tow this week
I purchased my 2011 Ram 1500 specifically for towing. according to the window sticker it has the LSD, 3.92 gears, 4x4 and 5.7 liter. I have to say that I was not impressed with the towing on this truck. I got on average 8 MPG going from VA to NC to West TN and back to VA. Obviously crossing some mountains but it had to drop into 3rd gear and run up to nearly 5k RPMs. The trailer was approx 3700 lbs loaded and I was using a Load distributing hitch.
Does this sound normal? I'm considering buying a travel trailer that will weigh in at 7100 lbs loaded but if this is now it handles 3700 lbs I won't be able to keep speed.
Any thoughts? How do I confirm the rear gear? I can't seem to find the window sticker at this time.
Eric
Old 06-12-2011, 08:13 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
I can't speak from personal experience but something doesn't sound right. I know a couple of guys with that setup that are towing a hell of a lot more weight and don't have any issues what so ever.
Big Red my old 2011 Sport
Old 06-12-2011, 08:25 PM
Ok so I found the window sticker and it does say 3.92 gears. I'm also getting noise from the drive train somewhere. Its like a dull hum or muffled grind sound. It occurrs between 35 and 50 mph under light acceleration but goes away when I let up off the gas. at 4600 miles I think it is time for a trip to the dealership. And to think this was my first new vehicle.
Old 06-12-2011, 08:28 PM
I also checked and the trailer was actually closer to 4100 lbs but still the GVWR should be 10250 for this setup. Another thing that is bugging me is that the door sticker says the GVWR is only approx 7k lbs. Shouldn't that take into account the gear ratio?
Old 06-12-2011, 08:44 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
None of that sounds like it makes sense. I have a 6x12 at a bit over 3000 lbs., not as much as you but not far off. I recently went through the Poconos and only occasionally did I even need the Tow/Haul mode. I averaged about 13 mpg.
Old 06-12-2011, 09:12 PM
Note that the trailer is a rental and I am now beginning to suspect that the trailer brakes might have a problem. I'm bringing the trailer back tomorrow morning so we will see. I checked the temps on the hubs by feel. 1 of them felt a little hotter than the others but there was no smoke or burning like I've seen in the past with uhaul trailers when the brake wasn't unlocked. When going down even a 4% grade I wasn't getting an increase in speed. Who knows. If I find out that it was the trailer someone is going to be providing me some gas money. Thats All I can say about that.
Old 06-12-2011, 09:17 PM
Rep:220
I think you have hit on the problem.
Old 06-22-2011, 12:52 PM
roll roll is offline
Vehicle: 2011 dodge ram
Trim Level: slt 4x4
Color: hunter green pearl
roll is on a distinguished road
Maxium GVWR is 6800,max.GCWR is 14,000 & 15,500 !Towed travel trailer that weighted over 7000 lbs. from western nc,towed in tow haul and 4th gear,got 8.5mpg,towed in tow haul 5th gear and got 9mpg on flater land !
Old 06-22-2011, 02:11 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
If you were in Tow Haul mode, it disables MDS which will hurt your gas mileage. I have hauled trailers in the 3-4K range and averaged close to 15 mpg in regular mode. I took it easy up hills, and coasted as fast as it wanted to within reason down the other side.
Also, there was a recall on the rear differential on the 2011's, I think K36 or something. You may want to mention that to your dealer.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-22-2011, 02:58 PM
Rep:2657
if you have a fill/check plug in the rear cover of your rear end, that recall does NOT affect you
you can see it by kneeling down near your trailer hitch & looking under your spare tire at the rear end center cover plate
to confirm your rear end ratio, when the truck is new & has not seen too much rainy weather, there will still be a paper sticker on the right rear axle housing, between the tire & the center pumpkin
[IMG]
another thing to consider, if you plan on doing any heavy towing, think about getting a after market cover that will give you a larger fluid capacity,
the Ram covers have to be taken off to change out your fluid, the fluid is synthetic gear oil, so when you are ready to change fluid, that would be the best time to change covers. Then you could get a larger capacity cover with a drain hole & magnetic plug
Approaching 3rd week of JS status Stump3r 2011 Dodge Ram Forum 6 03-28-2011 05:12 PM
Worst first week Ram experience... thatreddodge Dodge Ram General Discussion 16 12-23-2010 10:22 AM
Paris hits her 2nd milestone this week!! 10,000 posts!! City Slicker Off Topic Discussion 14 12-17-2010 12:35 PM
Vararam Intake $298 on sale this week only dragginbody Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 11-22-2010 05:40 PM
2 more mods coming this week :) rtkman 2010 Dodge Ram Forum 17 11-09-2010 10:25 PM
