Old 06-13-2011, 12:33 AM
white raven white raven is offline
Vehicle: 2002 Dodge Ram 1500 4x4 5.9ltr
Trim Level: slt sport
Color: blue
white raven is on a distinguished road
Default 2002 5.9ltr Air Conditioning Problem&Vents
My air conditioning blows cold air(not as cold as before) while I'm driving. If I stop at a red light or get caught in slow traffic it starts to blow warm air. Once I start moving at a normal speed it starts to blow cool air,not cold as before. Any help before I bring her in for a inspection would be awesome. Another thing is my blower feeds driver side vents more on dash and less on feet. The passenger side vents get more air(or heat) on feet and less on dash vents? Two problems that may be related,or not. Any help from you Dodge Boys would be great. James.
Old 06-13-2011, 09:49 AM
nikeman nikeman is offline
Rep:91
maybe you need to just have the ac recharged.
Old 06-14-2011, 01:32 PM
nim81's Avatar
nim81 nim81 is offline
Vehicle: 2006 TRX4 SLT Ram 1500
Trim Level: TRX4
Rep:19
nim81 is on a distinguished road
i had the same problem on my 02 5.9 id heard about a blend door being stuck somewhere causing this to happen. never did get it fixed and then bought my new truck.
ive heard you can get under the passenger side dash and remove the fan module and there is a door there behind the fan that may be stuck and you can push it open with your fingers and reinstall the fan.
Shhh! Chocolate. Once them deers smell that birthday cake them sumbitches will come a running.
Old 06-29-2011, 09:02 PM
HostileRam HostileRam is offline
Vehicle: 05 Ram 1500
HostileRam is on a distinguished road
The blend door only controls warm air or cold air through the vents. If the air is cold and you have A/C on then the A/C would have to be switched to heat for the blend door to switch over. They can adjust the blend door, however not related.
I have the same issue. Replaced, evap, dry box, filter, compressor so far and still same. About to replace condenser next.
Old 06-29-2011, 10:10 PM
I think you have two items going on here...a system that needs to be recharged and a faulty HVAC blend door or blend door actuator.
Old 06-30-2011, 08:33 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Your a/c has a fan underhood that will cause the problem you describe. Opem your hood and start your truck, on the drivers front of the engine bay is a small electric fan, this fan should be running. It works just like a radiator fan, its supposed to cool off the small radiator thingy (it goes to the a/c, condensor I think its called). The second issue is more then likely a blend door issue. If you choose to fix this issue yourself, you will learn more about your truck then you ever cared to know.
Sure it'll suck, but it'll make you a man
2001 Dodge Ram Air Conditioning westbygodtbone Heating & Cooling 1 05-03-2011 10:18 PM
Air conditioning question BigOrange Heating & Cooling 1 04-14-2011 09:36 PM
