truck won't start, but auto start works. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 06-14-2011, 08:42 AM
ali15 ali15 is offline
Vehicle: 2004 Dodge Ram 1500
ali15 is on a distinguished road
Default truck won't start, but auto start works.
the truck will not start when trying to use the key, but the autostart works. when started with the auto start, as soon as i press the brake, the truck turns off. the interior lights are dim when the key is in the ignition in "run" position and the headlights nor break lights turn on. no fuses are blown, tested all of them.
is this a factory alarm that could have entered into safe mode? have no idea how to get it to start. the key is black, not grey. tried the 2 spare keys, that didn't work. disconnected the battery for 10 minutes to try to re-set.. that didn't work. any ideas?? anyone have this problem before??
Also, the fuse box under the hood - is that the only one? there isn't an interior fuse panel under the steering wheel or in the dash?
(take it easy on me boys, i AM a girl!)
Old 06-14-2011, 02:35 PM
brokenwrench66's Avatar
brokenwrench66 brokenwrench66 is offline
Vehicle: 2009 1500 SLT 4X4
Color: Stone White
Rep:81
brokenwrench66 will become famous soon enough
Welcome to the Forumz!
Sorry to here about your starting issue. The dim lights are unusual, otherwise I'd say you have an issue with your ignition, that is, where the key slides in. If the auto-start works then you can rule out just about everything else in the ignition system.
Hopefully someone else will have had a similar issue and can help you better than I can. You can also search though the posts in the 3rd generation area of this site.
Good luck!
Dual Exhaust, K&N drop in, TFP chrome mirror covers, TFP stainless steel door handle covers, molded splash guards, Leer cap
Old 06-14-2011, 02:46 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. How about posting a few photos of your truck?
I'm not sure what the answer is, but how old is the battery and does it have a good charge?.
Old 06-15-2011, 07:03 PM
Still no luck. It's not the key relay, we swapped those around already. Replaced ignition switch. Called the alarm company to see if maybe there was a safety on it that disables the truck to start. None of those options. I don't know what else to do.
Old 06-15-2011, 07:48 PM
Rep:2962
It can't hurt to get the Battery checked out, load test after a FULL charge
Old 07-15-2011, 08:44 AM
Flamed03 Flamed03 is offline
Color: SILVER
Flamed03 is on a distinguished road
Hey Guys/Girls,
I am posting to this because my wife ALICIA and I are still stumped with this issue...
Long story short we finally took it to the Dodge dealer and they made us take it out of there and bring it to an Auto Image to have the alarm taken out of the trucker cause they said they wouldn`t touch it with it...
Anyway when it went to auto Image they advised as I knew it had nothing to do with the alarm , but took it out..When I went to pick it up they actually put a switch so I can start and drive the truck back to the dealer...Needless to say I have`nt brought it back yet, and I am driving my brand to truck off a switch wired to the ignition... Could this be the ingition switch?
FYI: While installing a radio the fuse popped in the dash, so when I tried the ignition switch the first time it didn`t work...do you think I should get another ignition switch and try that?
I am getting power to the switch, but no power back out?
I look forward to all help and answers.
truck wont start need help needhelp 5.9L V8 Specific Topics 16 03-15-2015 03:26 PM
Truck wont work/Key Fob won't work/wont start/wont do anything! nutsnbolt Electrical 24 12-16-2014 07:11 PM
96 Ram refuses to start. Fuel pump problems? Derek 5.9L V8 Specific Topics 9 11-28-2012 04:06 PM
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 09:14 PM
Remote Start Sometimes Works SEJO 2010 Dodge Ram Forum 19 01-31-2011 11:47 PM
