Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 06-14-2011, 02:32 PM
hammerheadn hammerheadn is offline
Vehicle: 2001 Dodge Ram 2500
hammerheadn is on a distinguished road
Default 2001 Ram 2500 A/C - sometimes blows hot - sometimes cold
I can't figure this problem out!!!!! Any input would be appreciated
In late evenings or night when sun & ambient temp down a/c works 100%.
Mornings drive to work park start up at lunch turn a/c on -- idle 45 mins. -- blows cold air the entire time.
************************** start up at lunch turn a/c on -- drive 2 miles down the road blows hot air
When driving and blowing hot air turn a/c off for approx. 5 minutes turn a/c back on and will blow cold air a couple of minutes then blows hot again.
Under the hood**
-- Compressor sound and appears to be cycling just fine.
-- Condenser is free of bugs and fins are 90% good.
-- Accumulator is never frozen up.
-- Engine never overheats.
In the cab ** No wet carpet below HVAC evaporator area to indicate evaporator freezing up or the evaporator drain is blocked.
Under the truck** After shutting truck off occasionally notice puddle of water underneath indicating that evaporator drain is not blocked
Have not checked ** Freon level (High or Low side pressure) -- that the a/c works 100% at times would indicate that the pressure and freon level is good.
Have recently replaced ** (not for this problem) 1) A/C and Heater Control Unit
2) Blower Motor
Need to replace ** (only have high speed on blower) Blower Motor Resistor
Old 06-14-2011, 06:19 PM
dsol dsol is offline
Vehicle: 96 dodge ram sport
Trim Level: sport
Color: red
dsol is on a distinguished road
sounds like the valve that crontrols the coolant that goes to the heater core isnt shutting all the way or possibly vibrating open. or even just be a lose blend door that isnt directing air flow properly
2003 dodge ram 1500 a/c blows cold only when moving asmith352 Dodge Ram General Discussion 4 04-25-2011 01:27 AM
2003 and later front brakes on a 2001 and older 2500 WVdieselOwner Newbie Checkin! 7 04-04-2011 09:31 AM
2001 2500 5.9 Magnum Cooling Issues? TheLoyale 5.9L V8 Specific Topics 2 12-05-2010 01:09 PM
2001 Dodge 2500 V-10 Tranny Slipping?>>> rfling Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 2 09-13-2009 07:16 PM
newbie from MN with 2001 Ram 2500 harofreak00 Newbie Checkin! 11 04-09-2009 08:54 PM
