Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-14-2011, 05:12 PM
trentowens92's Avatar
trentowens92 trentowens92 is offline
Vehicle: 2002 Dodge Ram 1500
trentowens92 is on a distinguished road
Default please help!I can't get out of park
Ok I installed my eagle eyes 3rd brake light checked the cargo light and it worked I started it and checked the brake light and it wouldn't work,then I went to put the truck in hear and I can't get it out of park.the gear shifter won't move.I tried the 4w4 and I can get in 4 high,w the truck in park,but cant get 4low or neutral and can't get the gear shift to move down to any other gears and have had no prior issues with it.
Oh yeah I did hook up the old light,it still won't work.please help
Old 06-14-2011, 05:22 PM
dwadestrick's Avatar
dwadestrick dwadestrick is offline
Vehicle: 2011 Ram Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:85
dwadestrick will become famous soon enough
Send a message via Skype™ to dwadestrick
Have you checked all the fuses?
Factory:
Break controller, Mopar Chrome Tubular Side Steps, Sprayed in bed liner.
Changed:
Bak Flip F1, Performance Hood, Remote start
Old 06-14-2011, 05:31 PM
I checked all the brake light fuses they fine any other ones I need to check
Old 06-14-2011, 05:35 PM
Rep:85
In the 2000 model there were some under the hood tied to the same ones in the cab fuse box. Not sure about 2002. Have you looked there?
Factory:
Changed:
Old 06-14-2011, 05:51 PM
where is the one inside the truck?I have been looking under the hood.I found on internet. That there was a cable attached to the ignition switch and it can cause the gear shift to not engage
Old 06-14-2011, 08:15 PM
Rep:85
There may not be one inside the cab. The 2000 model my dad had, had one on the driver's side dash and one on the drivers side under the hood. My 98 Chevy was the same way.
Factory:
Changed:
Old 06-14-2011, 09:16 PM
my 01 gmc did too this don't tho idk y.I figured it out tho.you had to take out the brake light bulb and put in the wire for the led piece and the wireson it weren't bent like they need to be and was blowing a fuse but we fixed it and it runs great now thanks for the help
Old 09-04-2011, 11:53 AM
02ramsport's Avatar
02ramsport 02ramsport is offline
Vehicle: 2002 Dodge Ram1500
02ramsport is on a distinguished road
my 02 did the same thing if you pull the panel under the steering wheel and find the shift cable and follow it up to where it connects to the lever there is a locking silanoid that is suppose to disengage when you stepon the brake. mine stopped working and the cable broke where it attaches to the lever.
Went camping at a near by state park Butter Off Topic Discussion 12 05-03-2011 04:55 AM
Mopars at the Park 2010 oreo Great Plains 9 11-07-2010 12:53 PM
Park Sense - How to Enable? RammD 2010 Dodge Ram Forum 16 07-06-2010 11:25 AM
No Park Assist Shoua 2010 Dodge Ram Forum 14 04-03-2010 01:34 PM
McKays Dodge- Waite Park, MN Zekery360 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 11 02-14-2010 08:56 PM
