United Radio
Old 06-14-2011, 09:15 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:360
Default Does DSP and/or Superchips alter tranny with a canned tune?
Hi all. I'm still kicking around the idea of a tuner, trying to decide whether I want the DSP or Superchips, and looking for a good deal. I'm also coming up with new questions all the time. Here's the latest...
Do these tuners alter your transmission or shifting in any way if you simply load one of their preloaded tunes (such as the 93 octane performance tune) or is the tranny alteration a stand-alone option?
Thanks!!
Old 06-15-2011, 01:34 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The superchips has several options. You can do a "quick tune" which basically is all preset options, and tunes based on the following choices: mileage xs, 87, tow, 91 perf, 93 perf. I've used the tow, 91 perf, and 93 perf quick tunes and they all alter trans shifting.....You can also do an "advanced tune" in the same settings: mileage xs, 87, tow, 91 perf, and 93 perf.... and you can customize your options such as rev limiter, tire size, gearing, fan on temps, etc.... I almost always have mine set up with the 91 perf "advanced tune" and adjust my fan on temp, I leave every other setting basically the same as the "quick tune". So in short, yes the tuning adjusts transmission, but there is another option called "stock with options" which I assume leaves everything stock including trans, but allows you to change tire sizes, gearing, etc...
Sean
Old 06-15-2011, 02:06 PM
The DS Predator has a shift firmness option and also a shift point at WOT setting option.
I didn't touch either one of them. My shifts did firm up a bit with just the canned 91 tune.
Old 06-15-2011, 03:13 PM
Rep:360
Thanks guys. I have read a lot of comments about people liking the improved shifting. I just plan in running the 93 octane performance tune and I was wondering if the modified shifting was part of this.
Old 06-15-2011, 09:31 PM
snrusnak's Avatar
Rep:1385
Yeah I ran the 93 tune when I first got the superchips but I changed to the 91 tune because anytime I had weight in the bed (even my 375lb buell) i would start to get detonation because of how far advanced the timing was. The guys at superchips told me the 93 tune only makes approximately 3-6 hp over the 91 tune, so I figured I'd run the 91 tune with 93 octane and be able to use my bed for light to medium loads without retuning(you're not supposed to haul/tow in the performance tunes because of the advanced timing). Now that I have been running the 91 tune I have easily hauled my bike amongst other things up to probably 1000 lb without any issues/struggling/detonation.
Sean
03' Dodge Ram 1500 4.7L Magnum - TRANNY PROBLEM - Did the shop screw my tranny up? emodpro 4.7L PowerTech V8 Specific Topics 3 09-16-2010 03:53 PM
New tranny and eng. t-stat, but odd temp behavior glostamann 5.2L V8 Specific Topics 1 03-13-2010 03:08 PM
Quick tranny question Excoastie 5.7L (345 cu in) HEMI V8 Specific Topics 4 02-28-2010 04:31 PM
No reverse in tranny YoMoma 5.9L V8 Specific Topics 16 12-08-2009 11:55 PM
