Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
tonneaucovered.com
Old 06-14-2011, 08:55 PM
MONT.RAM's Avatar
MONT.RAM MONT.RAM is offline
Vehicle: 2012 RAM 1500
MONT.RAM is on a distinguished road
Default trailer wiring
I am assuming that I have a factory tow package on my truck. I have the plug under dash for a trailer brake controller. Are there any other ways to tell? I looked and can't see any other plugs under bed bihind bumper. Looks like a damn mess under there. Factory plugs may have been there but been cut out. Does anybody know where i can find a tow package wiring diagram? I need to install a 7-way trailer plug for my camper. Just from a quick glance looks like wires might all be there but would like some kind of help.
Thanks.
2.5" skyjacker leveling kit. Tow mirrors.
Old 06-14-2011, 10:05 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Your truck may have had the factory trailer tow package, but that did not come with a wiring connector in that year. There should be a wire harness under the rear of the truck near the center of the bumper with 7 wires of the following colors/characteristics -
Red/Orange - +12V Battery (Thick Wire) From fuse #8 (40A)
Black/Orange - Tail Markers (Thick Wire)
Light Blue - Trailer Brakes (Thick Wire)
Violet/Black - Backup Lights (Thin Wire)
Dark Green/Red - Left Stop/Turn - (Thin Wire)
Brown/Red - Right Stop/Turn - (Thin Wire)
Black - Ground - (Thick Wire)
Under the dash, the brake controller wiring should be -
Black/Orange - Ground - (Thick Wire)
White/Tan - Brake Light sense - (Thin Wire)
Hope this helps.
brad
Interested in one of my mods?
Old 06-15-2011, 08:37 AM
MONT.RAM's Avatar
Thank you. I am pretty sure all the wires are there, just not going to the connector. Previous owner must have had to remove it for something, if it was even there like you said. Guess I will have some wiring to do.
Thanks
Old 06-15-2011, 08:53 AM
brad12kx's Avatar
Rep:2581
Chances are it never had a trailer connector. They were an aftermarket item in 99. Dodge only supplied the wiring in the truck to accommodate adding the connector without butching the trucks wires. It was around 2002 that they started installing a connector at the factory.
Good luck with your wiring, and just holler if you need any help.
brad
Old 11-11-2013, 12:29 PM
Hazzo Hazzo is offline
Vehicle: 1997 3500 Ram
Trim Level: Std
Hazzo is on a distinguished road
Brad12kx - thanks for the wiring key in this thread. I had the same question for my '97 3500 standard cab chassis truck. I found the 7-wires tucked in the left rear frame rail to add the bumper connector to but needed the wiring key as each of the wires was simply terminated with heat shrink tubing from the factory. I'll research www.etrailer.com and www.suspensionconnection.com for the appropriate 4-wire plug in brake controller. Todd
Need Help With trailer wiring JoAnne N Electrical 7 05-15-2011 12:07 AM
Dodge ram trailer wiring issue sullivan Dodge Ram General Discussion 13 03-09-2011 12:41 PM
Check trailer brake wiring warning lwalston Electrical 1 01-26-2011 07:21 PM
Trailer Wiring slikjr 2011 Dodge Ram Forum 4 01-19-2011 01:50 PM
Make a wiring adapter to convert 4 pin trailer lights to 7?? kdanderson5 Dodge Ram General Discussion 3 12-28-2010 02:40 PM
