tonneaucovered.com
Old 06-14-2011, 11:28 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default How much will it tow
I have a 2010 Ram 1500 Quad Laramie and want to tow approx. 8000 lbs. is there anyone doing such and if so how does the truck tow it/ any recommendations? I just ordered Airlift 1000 airbags for the rear springs b/c the travel trailer I'm looking at has a hitch weight around 650 lbs.
Thanks
Old 06-14-2011, 11:58 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
I regularly pull a trailer that ranges between 6500 and 7200 Lbs. I run a tongue weight of 500 - 800 Lbs. I have the Timbren SES suspension enhancement system.
Pulls great, average about 12MPG.
Here's a pic with the trailer at 7200lbs and about 800 on the tounge -
brad
Interested in one of my mods?
Old 06-15-2011, 10:30 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
You have plenty of motor, and I would suggest a trailer brake controller, but otherwise with the airbags you should be good.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-15-2011, 01:20 PM
I agree, you will be able to tow it fine. Just don't load up the truck with a ton of stuff and definitely put those helper bags on.
Also, given that hitch weight, I'd go with a Class IV receiver and a anti-sway hitch link. I don't think you'll need a load leveling accessory back at the hitch with the bags being installed.
Old 06-15-2011, 02:31 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
weight distributing hitch will be your friend
Old 06-16-2011, 11:14 AM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
Yes, you will need weight distribution and some sway control. You are pretty close to the max specs from Dodge at 8,000 lbs with a 1500. Here is the link that you can match with your trucks specs: http://www.dodge.com/bodybuilder/201...ammlup1500.pdf
And the 8000 lbs, is that "dry" weight from the trailer manufacturer or loaded? I pull a 29 foot travel trailer that weighs 5300 lbs "dry", loaded with gear, propane etc, it is probably close to 6,300 - 7,000 lbs, and it is enough trailer for the truck, I wouldn't want anything much bigger, really to be comfortable for any hills or wind.
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 06-17-2011, 10:22 AM
Vehicle: SRT-10
Rep:434
The travel trailer has a dry weight of 6850, i have a brake controller being installed and a AirLift 1000 airbag system for the rear springs. My calculations for max towing on a 1500 is about 7900lbs. So i figure I have aroud 1000 lbs of payload in the trailer/ truck bed.
How much do the stabilzer systems improve towability of most heavy trailers?
Old 06-17-2011, 10:54 AM
Vehicle: SRT-10
Rep:434
JJ, thats a great link. My truck is a 2010 and it has 3.92 gears so it says a 2011 will tow 9750, even conservatively I'm well below that and with 3.55 axle it shows a 8250 max tow. So as stated thats a great source of info.
Thanks
James
Old 06-17-2011, 12:13 PM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
They make a huge difference. My cargo trailer only weights about 1/2 what you're pulling but I use a stabilizer on it. Everything is just that more solid particularly in less than ideal conditions.
Old 06-17-2011, 01:04 PM
jj ram's Avatar
Rep:16
Thanks
James
With the 3.92 you will have no problem with that trailer, especially since that 8,000 will probably be your max weight, not "dry". Mine is 3.55 and it does well, but I wouldn't want any bigger trailer.
What trailer are you look at? Mine is a 2011 Kodiak 240KSSL.
How to: Hood Insulation / Radiator Cover Graphic Designs 10ramisport Dodge Ram Knowledge Base 2 05-01-2014 12:25 PM
How often do we pay extra for things and not even know we did? ArmyofOne Dodge Ram General Discussion 1 06-01-2011 01:08 AM
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 12:12 AM
!!how much would you charge?11 crob Dodge Ram General Discussion 5 04-21-2011 10:44 PM
How do you tell? Manogod Heating & Cooling 3 03-18-2011 06:15 PM
