Bell Tech 2/4 drop w/ shocks(4G) special tools? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-15-2011, 12:04 AM
Lie2me Lie2me is offline
Vehicle: 2011 CC 2wd
Rep:26
Lie2me is on a distinguished road
Default Bell Tech 2/4 drop w/ shocks(4G) special tools?
I've ordered the 2/4 belltech w/ shocks for my 11 cc 2wd and was wondering if I will need any specific tools to do this install. I'm doing it at a friends house next weekend and he's should have just about anything we need. I'm just trying to circumvent a trip to the parts store so we can can get it completed without taking all day.
Thanks
--Jeff
Old 06-16-2011, 09:07 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Jacks, jack stands, impact wrench, case of cold beer for afterward. Check, Check, Check!
Old 06-19-2011, 12:33 PM
Racerdamon's Avatar
Racerdamon Racerdamon is offline
Vehicle: 2010 Dodge Crew Cab
Rep:145
Racerdamon will become famous soon enoughRacerdamon will become famous soon enough
Default send it back
Make sure the rear shock bolts are the same size as the holes in the belltech shocks. my kit did not fit and belltech does not stand behind their product. also I hope you like riding on bump stops in the rear.
Old 06-20-2011, 02:05 AM
Rep:26
Racer, what did you do to fix this? Are you saying I will be riding on the bumpstomps because the shock doesn't fit? Or because the kit sucks? I hope I don't have this kind of experience.
Old 06-20-2011, 10:45 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
My Ram is a 03 not the same year as yours, I got the 5 inch rear flip and 2 inch drop coils from Belltech with the nitro drop shocks. I hardly ever bottom out. So i have no idea what is up with the above mentioned statement. Also have nothing but good things to say regarding phone support from Beltech as well..Good luck
Old 06-20-2011, 11:07 AM
Racerdamon's Avatar
Rep:145
What I did to fix this is put the stock shocks back on and added a 1 inch spring rubber to the belltech springs, this keeps the rear from bouncing off the frame on every bump. keep in mind that with the 4 inch drop there is around 2 inches of travel. so yes you will be riding on the bumpstops.
My 2010 dodge is a rare truck according to belltech because the shock bolts are different than any other dodge and that’s why the rear shocks doesn't fit? I hope you don't have this kind of experience.
belltech support sucks for me beecause they do not have a solution to fix my issue. they sold a kit for my truck that did not work and they are not willing to take it back or send me the correct parts.
Old 06-20-2011, 12:41 PM
iRESQu iRESQu is offline
Rep:2217
Having done a 2/4 Bell Tech Kit on my 2011 CC Ram I have this to say:
All my parts fit correctly and with no issues. I HAVE NEVER hit my bump stops even having hauled a 3800 lb vehicle on a trailer behind! Bell Techs customer service is the best I have seen for any business in a long time. I would recommend you call the retailer you bought your kit from, explain what's happening and see what they advise. Our first kit was incorrect. Summit had the wrong part number, got with BellTech and the problem was resolved with a new, CORRECT kit. Lastly, it sounds as though you didn't remove your bump stop cups. That would cause some of the issues you are complaining of.
DITTO my friend!
Old 06-20-2011, 02:30 PM
Racerdamon's Avatar
Rep:145
I called summit again (15+times )and they are now sending out another kit, I hope I can fix the rear as I love the front, but there is no way to put a trailer on it as it takes less than 300lbs to bottom the rear out. I will let everyone know if it fixes it.
Old 06-20-2011, 03:12 PM
Racerdamon's Avatar
Rep:145
Default pictures of the rear
Here is a picture of the Belltech rear bumpstop and the distance to the frame at ride height. and the last is of the inside of the rear shocks and you can see the hammer marks.
Old 06-21-2011, 07:25 AM
Rep:26
Racer, from the picture of your rear bumpstops, it looks like the bump-cup is still attached to the frame. The majority of folks I've talked to have cut those off, which is exactly what I plan on doing. I'm glad you got everything headed towards a fix.
Thanks for the input, it had me a little worried. I ordered mine thru Jeg's and have checked and rechecked part #'s to ensure there is no drama come Saturday morning.
I will post up once we get it installed.
thanks
Jeff
2010 r/t with 2/4 bell tech lowering kit grabberblue72 Dodge Ram R/T 37 06-17-2011 06:45 PM
Anyone had A load on with the Bell Tech 2/4 Drop? Jimbob Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 9 05-13-2011 11:42 AM
Bell tech shocks?! GregInAtl Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 11 02-22-2011 05:43 PM
