Bell Tech 2/4 drop w/ shocks(4G) special tools? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-21-2011, 07:26 AM
Lie2me Lie2me is offline
Vehicle: 2011 CC 2wd
Rep:26
Lie2me is on a distinguished road
Rescue, is your truck a 4x4?
Old 06-21-2011, 09:00 AM
iRESQu iRESQu is offline
Rep:2217
No Sir, it's a 2011 2wd CC.
Old 06-21-2011, 09:36 AM
Racerdamon's Avatar
Racerdamon Racerdamon is offline
Vehicle: 2010 Dodge Crew Cab
Rep:145
Racerdamon will become famous soon enoughRacerdamon will become famous soon enough
Default Rear bump stops
I do have the rear bump stop cups in per the belltech kit instructions.
I did cut the front ones out and installed the bolt in bump stops up front per the instructions.
To install the belltech bump stops in the rear, they push in the stock cups so that is the only way.
if I took them out of the rear, I would have major metal to metal contact on bumps.
Rescue, thanks for jumping in as I was so fed up with summit and belltech for the lack of support, it was frustrating
I gave them one last chance and they are stepping up so thanks for pushing me. (Im not going to use the PUN)
also do you run the rear bump stops in the stock cups?
Old 06-21-2011, 09:57 AM
Rep:2217
I am running with my rear stock bump stop cups.
Here is a brief summarization of what we dealt with when it came to Belltech and Summit.
http://www.ramforumz.com/showpost.ph...&postcount=121
Old 06-30-2011, 11:20 PM
Rep:26
I must say the install was really simple. Follow the directions. My partner kept wanting to take shortcuts and it just took us longer. Install was roughly 3 hours and an alignment is a must as soon as you can.
As for tools, the only thing that was a real pain in the but was the back side of the rear/driver side upper shock mount--solved this with a couple different combinations of an extension, deep well 22mm(or 24mm), and an angled socket. Spring compressor would be nice, but not necessary.
2010 r/t with 2/4 bell tech lowering kit grabberblue72 Dodge Ram R/T 37 06-17-2011 06:45 PM
Anyone had A load on with the Bell Tech 2/4 Drop? Jimbob Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 9 05-13-2011 11:42 AM
Bell tech shocks?! GregInAtl Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 11 02-22-2011 05:43 PM
