Old 06-15-2011, 10:00 AM
Victorio.garcia Victorio.garcia is offline
Color: Austin Tan
Victorio.garcia is on a distinguished road
Default 2010 Dodge Ram 1500 Spare Tire
Folks,
I have a 2010 Dodge Ram 1500 Big Horn edition. It came with an 18 inch spare tire instead of the 20 inch full size tire that is on the truck. I've heard the reason that a full size wasn't supplied is because the exhaust that comes out underneath the rear bumper is to close to the spare tire and would burn a full size spare. Is this a true statement?
Has Dodge come out with heat shielding that fits around the tire to prevent burning it?
If you need to run a full size spare (I pull a travel trailer) is the only option to reroute the exhaust??
Vic Garcia
Old 06-15-2011, 10:10 AM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Originally Posted by Victorio.garcia View Post
Folks,
Vic Garcia
I have the same truck. If I understand what you're saying I think you're confusing tire and wheel size... the tire is indeed a full size spare, but it's mounted on a smaller rim (I think a 17" actually), presumably to save money and weight.
Old 06-15-2011, 10:42 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
The factory spare is a P235/85R17 full size on a 17" steel wheel, temporary use
..same diameter (32.7") as a 275/60R20, just not as wide
235 vs 275 =40mm ...about 1.5" less width.
it weighs about 75lbs almost the same as stock 20's w/tire (80lbs) ...for those like me who like to drop it for racing weight reduction.
You can use an identical stock 20"wheel/tire for a spare if you pick one up on ebay or the local salvage pick-your-part.
...but the center bore hole may not allow the tire T holder to pass through (for those with Chrome Clad wheels) without some trimming.
Old 06-15-2011, 09:49 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
u cant put a factory alloy wheel under there b/c the winch won't fit through the centerbore, it has nothing to do with the exhaust. that temp spare is the same overall diameter.
Too many mods to fit here!
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 165 02-18-2016 08:35 PM
Dudes please help me out!!! 2010 cummins vs 1500??? Elite Cummins Diesel Specific Topics 31 07-25-2011 04:24 PM
2010 Dodge Ram 1500 Tow Hooks Schnitzer21 2010 Dodge Ram Forum 10 03-29-2011 09:23 PM
2010 Dodge Ram 1500 Laramie NAV Question limitlessent 2010 Dodge Ram Forum 5 09-06-2010 08:07 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
