ZDOG
Old 06-21-2011, 08:04 AM
yamifz1's Avatar
yamifz1 yamifz1 is offline
Vehicle: 2010 Ram 4x4 Sport
Rep:589
That really sucks, definitely a bad day!! Hope you manage to get it up and running soon.
RICHARD
14" Magnaflow,87mm TB, Vararam CAI,Diablo Trinity 91 Perf ,Edge 3000 Stall T/C, Tinted tail and 3rd brake light, rally stripes,Halo LED 55W HID projectors, LEDs inside and out, and many more options.
Old 06-21-2011, 08:46 AM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
Dang Thats not good. I agree drain everything and go from there
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
Old 06-21-2011, 10:09 AM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
what song is that BTW, I want to download it!!!
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Old 06-21-2011, 11:31 PM
sbsg2005 sbsg2005 is offline
Vehicle: 2001 Dodge Ram 1500 sport 4x4
Color: blue
Rep:23
sbsg2005 is on a distinguished road
I have been down this road twice in my jeep and once in the dodge. Although not quite as bad as this. The first thing I did was drain all my fluids(engine, trans, transfer, front and rear diffs). Yes this gets expensive. After this I pulled the plugs and poured some marvels mystery oil down each plug hole and used a breaker bar and turned the engine by hand about 10 times to make sure it turned freely with not binding. If there is any binding that would indicate a bent rod or some sort of other internal problem. Then I refilled all the fluids. I took every electrical connector apart and sprayed them with contact cleaner and put some dielectric grease in them. did the same to the all the fuses and relays. Took every vacuum line off and sprayed wd-40 through them to remove any water that might be in them. Then hooked the battery back up and turned the key and check to make sure I had all the normal dash lights. Which luckily I did so I tried to start it and it started. Then I drove the truck around for about an hour and let it get up to temp and stay there for a while. Then I drained all my fluids and and changed all my filters again. That was back 2008 for the truck and it is still on the road today with nothing more than normal issues. Now with as bad as yours went under you may have a few shorted out electrical parts to replace but with some junkyard shopping and internet searching and some patience you can find them pretty cheap. As for the smell dump a bag of tiddy cat in the floor boards and on the seats for a couple weeks to draw out any left over moisture then get the whole interior steam cleaned and it should go away.
Old 06-22-2011, 12:30 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
great advice for a water issue like yours.
Old 06-22-2011, 02:35 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
^^^^^^ Rep points for that post!
Old 06-22-2011, 01:03 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
After seeing this thread, it reminded me of a video I saw a while back. It shows just how powerful water can be and how dangerous driving over a flooded road can be.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-22-2011, 01:18 PM
ddalton ddalton is offline
Vehicle: 2010
Color: Mango
ddalton is on a distinguished road
I had a lil 4x4 dakota completely submerged for over an hour and drove it out and home. After a new air cleaner and spark plugs never had a problem!!
Old 06-24-2011, 11:42 PM
Color: blue
Rep:23
And I have a collection of bent rods due to people doing this^^^
Old 06-25-2011, 08:40 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Sorry to hear about your troubles but you got some really good advice above. I had it happen to an old honda I owned 30 year ago. We got it running after doing similar to what was mentioned above and it serves me well for another five years before I traded it in.
Need Help with starting problem after truck is warmed up Giddyup 5.7L V8 Specific Topics 12 01-11-2013 01:05 PM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
My truck got hit yesterday. GeauxHunting Dodge Ram General Discussion 41 11-19-2010 02:15 PM
Dirt Builds Up in the Bed of My Truck Rocky Harbour 2010 Dodge Ram Forum 4 05-27-2010 12:23 PM
Ontario Dealerships cuda71 Dodge Ram Dealer Issues - VIN and Order Tracking - Dodge Ram MSRP & Pricing Discussion 6 04-07-2010 03:10 PM
