Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 06-15-2011, 09:43 PM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
Default Bakflip F1 Driving Me Crazy
So I have had my cover for a while now and wrote up a big review.
Needless to say the cover is really bugging me. I get small amounts of water into it. I realigned the rails after I noticed a small gap, but that did not fix the problem.
I have a drop in bed liner so I added the seal and even caulked it so that the water would not leak under it.
While installing the cover multiple times and tightening and loosening it one side where the bolts is ended up spydering/cracking. This is because they drill the hole and do not put an sort of grommet into it. The pressure caused the the F1 black top to slightly crack. Annoyed by that, but the leak is not there.
Also when I fold the cover the inside edges are not very smooth and rub against the rubber seal. Not really impressed with my Bakflip.
Any help would be suggested. Could it be the front lip of the bed liner not sealing well?
Old 06-15-2011, 10:46 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Sorry for your troubles. I am pretty happy with mine. But I've only have folded it up all the way I think twice since I installed it back in February. It barely leaks, I take mine through carwash's a few times.
Did you stick on the shims to level out the side rails?
Old 06-15-2011, 10:55 PM
LeKy411's Avatar
Color: Blue
Rep:100
When I called Bakflip initiall when I had trouble they told me the Rams do not use nor need shims. Grrrr!
Old 06-15-2011, 11:19 PM
Rep:79
Directions are a little confusing. I didn't think i needed them either but before I tighten up the side rails I took a look and they seemed to tilt inward a little to much. You may want to look into this. Even if you don't have the supplied shim you could use a similar material. I think the shims were about a 1/8 of an inch think.
Old 06-16-2011, 09:45 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
I didn't need shims on my G2. I think the Bakflip is a great product but it seems like their QA is dropping the ball. I have a few quality issues that are really minor on mine. I wouldn't even worry about them if the thing wasn't so expensive.
Old 06-19-2011, 08:19 AM
RamOwner RamOwner is offline
Vehicle: 2010
Color: Mineral Gray
RamOwner is on a distinguished road
Did you ever get things lined out?
Old 06-19-2011, 01:32 PM
LeKy411's Avatar
Color: Blue
Rep:100
When I was looking for a solution I found the email address for the guy who owns the company and I emailed him about some of the issues I have been having with alignment and quality of the product. He told me to send him a couple pictures so i tossed them on photo bucket, but he hasn't responded yet with a solution.
Old 06-19-2011, 02:20 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
sorry to hear of your troubles there bud but i dont really have any suggestions as you covered pretty much everything...luckily i had mine installed where i bought it and i have no leaks so maybe try taking it to a shop to see if they can do anything about it
Old 06-19-2011, 02:34 PM
Vehicle: 2010
Color: Mineral Gray
I almost pulled the trigger on a purchase of the F1 UNTIL I encountered your post. Maybe yours is defective? Please let us know how things turn out though.
Old 06-19-2011, 03:09 PM
LeKy411's Avatar
Color: Blue
Rep:100
From what I have seen quality control is a little bit hazy. If you get one its either good or bad. When I fold mine up the mental bottom rubs against the seals and leave scuffs in them. I think driving with it folded would a disaster. I could do some shaving trimming and such but I would expect that from a $200 cover or something from Ebay, not a $800 product.
http://s1221.photobucket.com/albums/...Ram%20BakFlip/
bakflip g2 and bug deflector sudsy40 2011 Dodge Ram Forum 7 05-28-2011 12:05 PM
o2 sensor driving me crazy! gtthompson72 Newbie Checkin! 4 02-24-2011 12:08 AM
Bypass for Navigation typing while Driving? RammD Custom Dodge Ram Interior Modifications - Custom Audio / Video 6 12-28-2010 11:30 AM
Driving Me Crazy! Frank Cummins Diesel Specific Topics 1 06-16-2009 05:14 PM
i've got some driving noise Drakon543 Suspension 5 12-02-2008 11:09 PM
