Old 06-16-2011, 01:17 AM
aiminspects2001 aiminspects2001 is offline
aiminspects2001 is on a distinguished road
Default Can I go from manual climate crontrol to automatic climate control?
I Took off the bezel for the stereo and saw that the manual climate control plugs into a harness. Can I get the module for automatic climate control and plug it into the same harness? Will I need to add anything in order for it to work?
Old 06-16-2011, 04:57 PM
I believe you can do this. However, I suspect you'll need the controls, a sensor for in-cabin temps and a PCM flash for it all to work.
Old 06-16-2011, 10:18 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I have the dual zone climate and it has sensors allover the cab so it knows where to send the temp adjustment.
The control itself should be a simple change but routing the sensors could be a painfull process.
Old 06-16-2011, 10:19 PM
That ^^^^ is a very good point!
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 04:59 PM
Loose knob on manual climate control measel 2011 Dodge Ram Forum 6 05-28-2012 11:01 AM
Dual Zone Climate control issue billw Heating & Cooling 3 12-31-2010 09:29 PM
climate control zjp692004 Dodge Ram General Discussion 1 11-10-2010 08:59 AM
Auto Climate control Question SoDakMac 2009 Dodge Ram Forum 11 10-16-2009 01:46 AM
