Old 06-16-2011, 07:04 AM
redrum redrum is offline
Vehicle: 2012 ram qc express 2wd
redrum is on a distinguished road
Default Tire light after leveling it?!?!
I have searched... After i installed my 2.5 rough country spacers last night (which took 5hrs due to bottom shock bolt on passenger side) my tire monitoring light came on and will not go off. Tires are nitrogen filled. I even drove 30 miles to work this morning hoping it would reset... Any suggestions?! Thanks guys!
Old 06-16-2011, 09:04 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Did you knock a sensor loose whith the kit installation?
Old 06-16-2011, 09:12 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Sounds like a sensor got moved
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 06-16-2011, 09:17 AM
Where are these sensors located? Thanks
Old 06-16-2011, 09:32 AM
RedRam10's Avatar
Rep:743
Here's a write-up from our sister site. Not sure about the receiver location, but: http://www.nitroforumz.com/archive/index.php/t-627.html
Did you have any other mods to wheels or tires at the same time?
Old 06-16-2011, 09:41 AM
No, nothing. Just simply removed mine to do the leveling kit install. I guess i will have to pull the wheels an look for sensors. The light has never came on since i had the tires filled with nitrogen over a year ago
Old 06-16-2011, 09:45 AM
RedRam10's Avatar
Rep:743
Have you checked the tire pressure manually? I had a strange situation on my daughters car and found after much looking a slow leak in one of the tires.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 12:59 AM
Low tire pressure light wont go away? Hosslt1 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 11-06-2010 11:40 PM
Tire light flashes sometimes, but tires are fine. sinistersix Dodge Ram Wheels And Tires 2 10-24-2010 12:41 PM
Leveling kits and tire combo Dodgeramhemi2003 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 01-23-2010 09:59 AM
