Old 06-16-2011, 11:51 AM
moose3 moose3 is offline
Vehicle: 2011 Ram
Trim Level: Sport Crew w/Rambox
Color: Deep Cherry Red
Rep:36
moose3 is on a distinguished road
Default RRT: WIN (Wireless Ignition Node) Flash
Just had my truck in for some other issues. They performed a Flash of the WIN (Wireless Ignition Node) or sometimes referred to as WCM (Wireless Control Module). Apparently in response to RRT 10-047. It has to do with intermittent remote start. I hadn't experience any issues, they just did it as I was having other warranty work done.
http://www.sequentialtaillights.com/...LC_0802411.pdf
Hadn't seen this mentioned any where here yet.
Old 06-21-2011, 11:08 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 06-22-2011, 12:27 AM
nikeman nikeman is offline
Rep:91
thats interesting. I remember back when I first got the truck home I tried to show off the remote start and for some reason it did not start... It just locked all the doors and gave up I guess. It has worked flawlessly ever since then but I will have to look into this.
Old 06-22-2011, 12:21 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
It says remote start but I wonder if it would help fix an intermittent problem I have with the remote lock. Every now and then my key FOB wont unlock/lock the doors when I'm pressing the button.
Old 06-22-2011, 12:28 PM
Rep:2657
MY FOBs were acting up like that, dealer FLASHED the truck, it sort of worked
Then i got caught outside my truck in a down pour, groceries in both hands
I went to the dealer again, they ordered new Fobs & Flashed the unit again
all done under warranty
works 99% of the time now
Old 06-22-2011, 12:36 PM
Vehicle: 2011 Ram
Rep:36
I didn't have any known issues either. One time I think it didn't start, but I had the drivers door open, so I assumed that was it. I mentioned it because some may think be having issues and think that it was just being a fluke, when there really is a known issue and a solution. Kind of like the shifting issue, I thought it was just a fluke deal with that trans, turns out there is a solution.
Spreading the information to those in a forum.
Old 06-22-2011, 03:24 PM
GolfSIX GolfSIX is offline
Vehicle: 2010 Ram 1500 QC
Rep:25
GolfSIX is on a distinguished road
I too have issues with the doors not locking/unlocking when the fob buttons are pressed. I just assumed the battery in the fob was dying but perhaps theres another issue.
Si Vis Pacem...
Old 06-22-2011, 05:04 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
there are alot of posts about our key fobs, some possible soulutions:
Open them up, and slightly bend the battery contacts to increase the contact tension on the battery.
Install new battery, if older or weak
operate you fobs, from a greater distance away from your truck, they don't work sometimes if your too close
try hitting the lock button a few times, until it activates, then the un-lock button will work again
seems to be a rather common complaint with our trucks
So it is written ! So it shall be done!
Two Flash Updates at last Service bgerard 2010 Dodge Ram Forum 10 02-29-2012 06:44 AM
OEM brake controller flash Jgroes 5.7L (345 cu in) HEMI V8 Specific Topics 1 10-14-2010 11:48 AM
Ignition problem andrewdains Electrical 2 05-22-2010 02:35 PM
Anyone running MSD ignition box? Zekery360 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 0 10-12-2009 06:08 PM
HID's flash with keyfob and opening door?? Danstona Electrical 4 04-13-2009 11:38 AM
