Overdrive - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-17-2011, 12:30 AM
ramonator44 ramonator44 is offline
Vehicle: 1997 Dodge Ram
Trim Level: Laramie SLT
Color: red
Rep:22
ramonator44 is on a distinguished road
Question Overdrive
is overdrive on when the light on the button is on or off... also should i leave it on most of the time?
1998 Ram Laramie SLT 5.9L
Old 06-17-2011, 02:49 AM
Zac2109's Avatar
Zac2109 Zac2109 is offline
Vehicle: 2011 RAM 2500
Rep:56
Zac2109 will become famous soon enough
on my 98 when the light comes on it says overdrive off, and yes it should be on all the time unless you are driving through steep hills or towing, unless you like getting worse gas mileage
2011 RAM 2500 6.7L Cummins, 1968 Ford Mustang Coupe 289 V8
Old 06-17-2011, 01:49 PM
Color: red
Rep:22
does yours have the button up on the dash above the radio?
Old 06-17-2011, 02:12 PM
I run in O/D at freeway speeds only. Around town I am always in O/D off due to throttle lag, slipping the trans or lugging the engine, causing excess heat in the trans.
Old 06-17-2011, 02:25 PM
Zac2109's Avatar
Rep:56
my button is on the end of my column shifter
Old 06-17-2011, 05:05 PM
Jonesey982's Avatar
Jonesey982 Jonesey982 is offline
Vehicle: 2007 Dodge Ram
Jonesey982 is on a distinguished road
So, it's ok to run with it off in city driving? I've heard differently from my local shop. I've always wanted to do it during city driving cause it disables the MDS also. The MDS is beneficial when highway driving but city mileage is going to be 11-14 regardless of the MDS being on or not. So, if you do this all the time with no problem I'll be doing it too.
Old 06-18-2011, 03:44 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
If I'm not mistaken when your light is on it is indicating to you that your o/d is off. I personally drive with it on around town and definitely on when driving on the hwy. Now and then I take it of when driving red light to red light.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
07 overdrive problems 06yamaha450f 4.7L PowerTech V8 Specific Topics 16 04-22-2014 01:54 PM
545rfe 4.7 Overdrive Lagging Woot1337 4.7L PowerTech V8 Specific Topics 4 04-03-2014 08:25 PM
Overdrive Dann LD RAM - General Discussion 10 08-13-2011 08:29 PM
99 1500 5.9 Overdrive Lock-up Problem. delineated 5.9L V8 Specific Topics 3 01-19-2011 06:15 PM
A question about overdrive gear... DodgeGuy85 5.2L V8 Specific Topics 4 07-30-2010 08:35 AM
