Old 06-18-2011, 12:26 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Default 180 deg thermostat okay for winter?
I've read a billion threads on 180 deg stats but I still have a question for everyone. I live in northern NC and the average cold temps in winter is probably 15-30 degrees with the really cold nights dipping down a little lower. Is there any reason I would have any problems if I switch to a 180? I'm not willing to switch the thermostat every winter, lol.
Thanks.
Old 06-18-2011, 01:35 PM
BigBlue07's Avatar
BigBlue07 BigBlue07 is offline
Vehicle: 2007 Dodge Ram
Trim Level: ThunderRoad
Color: Electric Blue
BigBlue07 is on a distinguished road
Great question, I've got the same concern about winter temps. I'm in eastern NC but it still gets pretty chilly here. Maybe someone up here can enlighten us...
~ A sure way to drain life of its savor is to keep a death-grip on it. ~
Old 06-18-2011, 03:33 PM
Won't be a problem. Just make sure you let the truck idle and warm up in the morning before you head down the road. If you don't, you might get a CEL that advises you that your coolant temp is below acceptable limits, especially on short trips.
Old 06-18-2011, 11:53 PM
Rep:367
Thanks for the reply but I'm trying to wrap my head around this and I'm a still a little confused. I think I read somewhere that the engine has to reach 165 degrees...I'm guessing within a certain amount of time....or it will set off the CEL?? I may be totally wrong but I could swear I read that somewhere. If that is correct I don't see how the 180 deg stat could ever possibly set a code. The engine would always be much warmer (15 degrees) than the error limit before the 180 deg stat would be any different than the stock 195. The 180 should warm up to 180 just as fast as the 195 shouldn't it?
A potential problem that I was afraid of was once you get going down the road in 20 degree weather. The 180 shouldn't keep the engine from reaching at least 180 because once again it's no different up to 180 that the 195 right? But what is the chance that once it hits 180 and the stat opens to cool the engine that the cooling system (aided by the cold weather) would actually bring the engine temp back down below 165 and set the CEL?
Old 06-19-2011, 11:09 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I don't believe it would throw a code...you shouldn't have any issues, from what I read no one else has had any issues. The only way to really know is to do it an monitor your gas mileage, if it is affecting it you'll notice a drop by a few mpg.
Sean
Old 06-19-2011, 11:35 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i wouldnt think it would throw a code either or there would be threads on it lol but there are a few ppl on here that have this with no problem that iv herd of so you should be fine
Old 06-20-2011, 03:00 PM
The same thing could happen with the 195 T-Stat given very cold ambient conditions.
Yes, you want your engine to reach at least 165...thereby the suggestion to let it warm up before you hit the road in colder ambient temps.
The upside of the 180 is that the engine runs cooler in hotter ambient temps. In colder weather, it will close sooner as well.
Thje 180 will actually open earlier than the 195 because it takes less time to get to 180 than it does to get to 195.
Most folks I know who have gotten that particular CEL have 170 degree units in.
Old 06-21-2011, 01:41 AM
Rep:367
Yeah I guess theoretically your engine could drop below 165 while driving in cold enough weather even with a 195 deg stat....but my thinking is that with a 195 your engine is going to be 195 before the stat opens to let the coolant flow. So the coolant and cold weather are going to have to bring the engine temp down 30 degrees to create an issue. With the 180 it isn't going to get above 180 if things are working properly so it will only have to cool it 15 degrees to set the code. I'm not saying that it would happen with either stat....just that it seems more likely with the 180.
Also, I don't see how waiting for your engine to warm up before heading down the road is going to help. The engine temp is going to behave exactly the same up to 180 deg no matter which stat you have right? And letting it sit and warm up isn't going to help with a 180 deg stat because even if you let it run until it hits 180 the stat will open and the temp is going to level off. Is this correct or am I missing something?
I've also been doing a lot of reading about programmers and 180 deg stats. A lot of people say that a 180 will cause your engine to run richer. If so, would it be enough to create a noticeable difference in mpg?
Old 06-21-2011, 02:27 AM
Rep:2616
I am guessing here
i think the only difference would be how hot your heater system gets
it will only warm the heater hoses & core up to 180, so on real cold days, you may shiver a bit longer
household water heaters are usually set at 125 F (51.66 C). holding your hand under the faucet for around 2 minutes, can burn your hand
Old 06-21-2011, 08:38 AM
snrusnak's Avatar
Rep:1385
The only reason it would run rich is if it were not reaching proper operating temperature (which according to others posts seems to be 165). If this happens it also would not be constant, you would lose a couple mpg at most. I doubt this would happen. If it stays above that minimum temperature, it will not run rich or lose mpg, it would help it if anything due to the engine being slightly more efficient (outputting more work, and less heat)
Sean
180 thermostat gasket Raneman Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 06-21-2011 11:12 PM
Thermostat question? bfinley Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 7 02-09-2011 04:44 PM
1997 318 thermostat ajay080672 Heating & Cooling 5 01-14-2010 09:43 PM
Thermostat Jack B 4.7L PowerTech V8 Specific Topics 4 12-14-2009 10:40 PM
180 degree thermostat works lmurry51 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 5 10-03-2009 09:50 AM
