Wheel Spacers - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 06-18-2011, 03:31 PM
Taylo1's Avatar
Taylo1 Taylo1 is offline
Vehicle: 2014 Ram 1500 4X4
Trim Level: Outdoorsman
Rep:88
Taylo1 will become famous soon enough
Default Wheel Spacers
O.K. i have read alot on the size of tire that will and won't fit on the 4th Gen. trucks and before I spend money on tires and Maybe spacers I would like to know everyone's opinion on the 1/4" wheel spacers.
1. Will I need longer studs?
2. Any problem with the wheels staying on?
3. Has anyone had any problems since putting them on?
Old 06-19-2011, 05:27 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
For 1/4" you don't need longer studs. It is always a good idea to occasionally check your lug nuts especially with spacers and I've put 20k+ miles with 1.75" wheel adapters on a Cummins but that doesnt mean you won't
Old 06-19-2011, 05:32 PM
I agree with that ^^^^. It's better not to use them if you don't have to. If you make sure you get the right offset on your wheels, spacers won't be necessary.
Old 06-19-2011, 07:10 PM
Taylo1's Avatar
Rep:88
Yea, I wasn't wanting to spend the extra on new wheels when the stock 20's look pretty good, but I want a wider tire and didn't know If the 1/4" spacer would be a problem. Spacer = 100.00 Wheels = 1000.00
Old 06-19-2011, 08:01 PM
Color: Mineral Gray
Rep:177
$100 for 1/4" is way to much for spacers unless they are hubcentric
Old 06-19-2011, 08:49 PM
Taylo1's Avatar
Rep:88
They are Hubcentric, I was looking at wheeladaptor.com. still have not decided to go new wheel and tires or just tires and spacers! Just trying to find some information on the spacer and if any one has had any problems with them.
Old 06-20-2011, 08:02 PM
keegles's Avatar
keegles keegles is offline
Vehicle: 1998 dodge 1500
Color: driftwood
Rep:19
keegles is on a distinguished road
i wouldnt recomend wheel spacers. you could run into alot of problems if you go out off roading, or are on rough roads. but, 1/4 inch would be the max i would use if i were to do spacers at all. and i would only do spacers if i were running into rubbing issues. iv seen alot of guys throw wheel spacers on their prerunners, or "wannabe prerunners" aka brophy trucks, and bend their spindle snouts, or bust the stock studs. if you are having rubbing issues you could look at your spindle and see if it has a steering limiting bolt. im unsure if your truck has them. but you can adjust the bolts to keep your tires from rubbing. but you loose a little turning radius, a smidge.
Old 06-20-2011, 10:44 PM
Taylo1's Avatar
Rep:88
Thanks for the Info. Yea, I was only going to use them for rubbing issues, but I think I will just buy new wheels if I want new tires or choose a different size tire.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Wheel Spacers? NickDangerXJ Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 03-22-2011 05:12 PM
Anyone using 5/16" wheel spacers? xopt1js Dodge Ram Wheels And Tires 4 03-02-2011 04:32 PM
wheel spacers tinniste 079 Dodge Ram Wheels And Tires 9 11-22-2010 05:17 PM
Wheel Spacers causing severe Wheel Wobble nantuzzi Dodge Ram Wheels And Tires 3 06-10-2010 10:17 PM
