Old 06-19-2011, 12:35 AM
Tumbler's Avatar
Tumbler Tumbler is offline
Vehicle: 2010 Ram 1500
Tumbler is on a distinguished road
Default Shudder at WOT
Well I finally got my truck back from the dealer (4 weeks, long story) after having the Stage I Ram Runner suspension install which is basically the Kore Prerunner suspension. I am runnning 17" ATX with 35" Cooper Discovere AT3's. If I accelerate at WOT from a complete stop I feel a temporary shudder, which disappears at 20-25 mph. If I hit WOT at any other time, nothing. At highway speeds it rides like a cadillac--no shudder or wobble. If I hit WOT on the highway it kicks down to 2nd and goes and goes. Also handling and cornering are vastly improved.
Before the upgrades I didn't have the take-off shudder issues, maybe a little wobble at 70-75mph which is now gone.
Could the TC or some other driveline component be acting up with the weight of the new wheels and tires? I have a non-stock rear swaybar. It wasn't removed with the Kore install. Could that be the problem?
Any advice or theories when be helpful. Thanks.
Does it come in black . . .
Old 06-20-2011, 05:54 PM
The only thing I can imagine going on here is that the tire blocks are causing this. I had some Cooper Discoverer tires on a Blazer and this Ram and got the same shudder just starting out. And it didn't matter whether the tires were cold or warm. But they were also a MT tire so this might not be the case with your AT tires.
I assume your wheels are torqued properly and that your u-joints are in good condition.
Old 07-11-2011, 09:52 AM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Trim Level: Laramie Limited
Rep:32
dankent is on a distinguished road
With your install did they also install the High Angle CV's ? I beleive the take off shudder you feel is the same as the one people get when they do the 2 inch leveling kits. The kore ramrunner kit includes these ... but your kit may not have.
http://www.koreraceshop.com/dodge-15...-cv-joint.aspx
engine shudder after IAC and throttle body plugs out thunder92 5.9L V8 Specific Topics 3 06-18-2011 05:10 PM
Shudder, vibration or misfire under light to moderate throttle pickupman 5.9L V8 Specific Topics 4 06-01-2011 11:25 PM
Shudder brusk 5.7L V8 Specific Topics 8 10-07-2010 01:37 AM
Shudder under a load JR23 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 3 05-08-2010 06:04 PM
04 Launch Shudder -TSB- Kens04 Suspension 0 10-06-2009 10:05 AM
